After the completion of the power-on test, we found that the USB could not identify the device. After replacing the Flash with the configuration file, the USB device could be used normally. So I want to ask how to burn the configuration file.
So you hit issue before flashing the device? Which Jetson module are you using?
The Orin NX,the base plate is of its own design.
I am not sure if the Flash file of the HUB chip needs to be burned separately or if it was burned automatically during the download process.
Could you provide the more detail like
- Which commands you flash?
- How you replace the flash with the configuration file.
- Flash log and serial console log attached as file provided.
What does that mean “the flash file of the Hub chip”? If you are adding a USB hub chip by yourself, then you should ask the vendor to provide the software for you to use.
We don’t know and won’t know what flash file for your hub chip would be in use unless the thing you are talking about has nothing to do with your hub chip.
