zw_sd
#1
In python, I tried below codes:
jetson.utils.cudaOverlay(img, img.width, img.height, img_out, img_out.width, img_out.height, img_out.format, 600.0, 200.0)
But I got below error:
Exception: jetson.utils – cudaOverlay() failed to parse args
Could you please suggest the right way to call jetson.utils.cudaOverlay()?
Thank you.
Hi @zw_sd, you can see an example of jetson.utils.cudaOverlay() Python function being used here:
https://github.com/dusty-nv/jetson-inference/blob/master/docs/aux-image.md#overlay
cudaOverlay() will get the image width/height/format from the image object, so you don’t need to explicitly pass those in. Try this instead:
jetson.utils.cudaOverlay(img, img_out, 600.0, 200.0)
