Jetson Xavier NX • DeepStream Version
DeepStream 6.0 • JetPack Version (valid for Jetson only)
4.6.1-b110 • TensorRT Version
8.2.1.8
I am trying to draw centroid marker on the display from DeepStream with python bindings. I assume pyds.NvOSD_CircleParams class can be used for the purpose. However I am not sure how to use this in the program… Could anyone show me a sample code for drawing?
Similar way to getting display_meta from batch_meta as the way in deepstream_test_1.py, then getting circle_params from display_meta, and then you can set the circle-related parameters as defined in pyds.NvOSD_CircleParams class.
