How to drop frames when the pipeline gets slow?
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.2*
• Issue Type( questions, new requirements, bugs) questions
Due to some computational issues at the probe, the pipeline has become sluggish and eventually terminates. I am actively working on reducing the complexity at the probe to improve performance. However, I am also interested in learning how to discard frames when the pipeline experiences slowdowns. I have attempted to address this by adding a queue with the property leaky set to 2, but it appears that this solution is not effective. Could someone please suggest a solution to this problem?
Hi @daredeviles888
You also need to set the max size, otherwise the queue won’t drop any buffers. Try placing the queue before the element that is causing the bottleneck.
queue leaky=2 max-size-buffers=1
Another option is limiting the DeepStream processing interval using the interval property on nvinfer.
It should work if the “queue” is set correctly in proper place.
You can also add “videorate” to slow down the stream before the probe.
