I want to display the following video side by side so that I have 2 1280x720 frames creating a 2560x720 frame (equivalent to using hconcat in OpenCV). Is it possible to do this in a gstreamer pipeline? Here is the pipeline to get the camera stream:
I tried this to duplicate the camera stream using nvcompositor but it failed. I don’t think I can open 2 sources of the same camera at once. Is there a way I could use the tee method to send the same stream to sink 1 and 2 and duplicate the stream on screen?
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:736 Failed to create CaptureSession
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 4
Output Stream W = 1280 H = 720
seconds to Run = 0
Frame Rate = 59.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
Redistribute latency...
pixel_format must be RGBA for blending operation
nvbuffer_composite Failed
Got EOS from element "pipeline0".
Execution ended after 0:00:00.644832697
Setting pipeline to READY ...
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
Setting pipeline to NULL ...
Freeing pipeline ...
Actually I think the issue with the nvcompositor is that is expects a RGBA format but I’m sending a NV12 format. How would I perform the conversion to get RGBA?
I get an error saying WARNING: erroneous pipeline: could not link nvvconv1 to comp, comp can't handle caps video/x-raw, width=(int)1280, height=(int)720, format=(string)RGBA
This works using videocompositor but It’s 2 different csi cameras, I’m not sure how to use the tee operation here. It also makes the framerate very low:
That gives a error reason not negotiated (-4) but if I run it with nvoverlaysink there is no error (but obviously it doesn’t display because the sink is depracated)
