How to edit an array?
Hi all.
Could you be so kind as to tell, whether the parallel solution of the problem?
I need to make a copy of array by removing the marked elements from it.
Marked elements are to order more.
The algorithm does not have to be correct, a small portion of marked elements may remain, but it must be fast.
“The algorithm does not have to be correct”
nice
if the marking of elements is in the form of a boolean or integer - true/ false or 1/ 0, you can sum-scan this predicate, to obtain the location of remaining elements in the new array
you would then write elements to the new array, if their predicate is set (true/ 1), and according to the sum-scan
should be chop-chop
for (elements)
sum-scan predicate[i]
if (predicate[i])
new_array[sum_scan[i] - 1] = array[i];
Thank you, amazingly simple.
