How to eliminate abnormal level changes on the SPI interface
How to eliminate abnormal level changes on the SPI interface.
I am using the Jetson Orin Nano platform, which is not the official development board. I need to use the SPI interface to transmit video data at 50 frames per second. Each frame takes about 21 ms to transmit 25,600 bytes.
I am using both SPI0 and SPI1, and the following phenomenon appears on both:
  • SPI_CS is active low. The low-level duration is about 16 ms, but at about 10 ms into the low period, there is a pull-up glitch followed by a pull-down return.
  • During the 16 ms SPI_CLK output window, at about 10 ms, there is a glitch where the clock pulls low and then high again.
The duration of the abnormal waveform is about 40 µs.
I am not sure what causes this. Does this abnormal waveform affect data transmission?
Hi 1223389176,
Please check if the patch for CS from the following thread helps for your case.
Jetson orin nano SPI Speed not changing - #9 by KevinFFF
