How to enable A/B update and A/B redundancy
I am struggling to enable A/B update and A/B redundancy on Jetson AGX Xavier following the documentation below
Jetson Xavier NX / AGX Xavier
Edited smd_info.cfg
# SMD metadata information
< VERSION 3 >
# Config 1: Disable A/B support (Default)
# slot info order is important!
# <priority>    <suffix>     <retry_count>  <boot_successful>
###15                  _a          7               1
# Config 2: Enable redundancy support (by removing comments ##)
< REDUNDANCY_USER 1 >
15                  _a          7               1
14                  _b          7               1
Then after modifying the smd_info.cfg, the next step is to make the BUP file
Linux_for_Tegra$ 	cd bootloader/
bootloader$ 		sudo ./nv_smd_generator smd_info.cfg slot_metadata.bin
Finally, run the NVIDIA flashing tool:
Linux_for_Tegra$ sudo ./flash.sh -r -k cpu-bootloader jetson-xavier mmcblk0p1
But unfortunately on the target device I don’t have the expected setting
tux@tux-desktop:~$ sudo nvbootctrl dump-slots-info
magic:0x43424e00,             version: 3             features: 0             num_slots: 1
slot: 0,             priority: 15,             suffix: _a,             retry_count: 7,             boot_successful: 1
slot: 1,             priority: 0,             suffix: ,             retry_count: 0,             boot_successful: 0
What is missing there?
…an update
Is mandatory to run the NVIDIA flashing tool for the whole system (all partitions again):
Linux_for_Tegra$ sudo ./flash.sh jetson-xavier mmcblk0p1
Now this is the result on the target
[sudo] password for tux:
magic:0x43424e00,             version: 3             features: 3             num_slots: 2
slot: 1,             priority: 14,             suffix: _b,             retry_count: 7,             boot_successful: 1
Hi MarukoBG,
Please try using the nv_update_engine tool to enable redundancy.
  1. Create the BUP image and copy “bl_update_payload” to /opt/ota_package:
    $sudo ./build_l4t_bup.sh jetson-xavier mmcblk0p1
  2. Check current slot:
    $sudo nvbootctrl get-current-slot
  3. Enable A/B redundancy:
    $sudo nv_update_engine --enable-ab
  4. Update engine:
    $sudo nv_update_engine --install
