I refer to the
Hi Sir:
I want to enable TPM2.0 driver in SPI1 in Xavier, following is the description in DTS file:
spi@3210000 {
status = "okay";
spi@0 {
compatible = "spidev";
reg = <0x0>;
spi-max-frequency = <33000000>;
nvidia,enable-hw-based-cs;
nvidia,rx-clk-tap-delay = <0x11>;
slb9670: slb9670@0{
compatible = "tcg,tpm_tis-spi";
reg = <0x0>; /* CE0 */
#address-cells = <1>;
#size-cells = <0>;
spi-max-frequency = <5000000>;
tegra194-p2888-0001-p2822-0000.dts (361.8 KB)
The driver appears to be running
[ 0.904443] GPIO line 256 (tpm-rst-pin) hogged as output/high
[ 1.813707] [TPM]tpm_tis_spi_probe:
[ 1.813714] [TPM]tpm_tis_spi_probe:tpm_tis_core_init 1
but don’t see any spi or tpm device
How to test that tpm is working
20220601_xavier_htb_kernel.log (79.4 KB)
kayccc
June 1, 2022, 10:13am
#2
Is your TPM module the same as the reference one?
Have you work with your hardware engineer to probe the signaling for verification.
I see
Hi Robinchen,
Is your TPM working with Xavier ?
If yes, can you share DTS entry ?
Alks
CS is main issue during TPM bringup. Need to define as “cs-gpios”. ???
How to define “cs-gpios” ?
kayccc
June 13, 2022, 2:04am
#4
Could you trace the …/kernel/kernel-4.9/drivers/spi/spi-gpio.c to confirm the configure.
enable spi pinmux
bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
can see /dev/tpm0
user@user-desktop:~$ ls /dev/tpm0
/dev/tpm0
but kernel show error message
[ 0.887624] GPIO line 256 (tpm-rst-pin) hogged as output/high
[ 1.787232] tpm_tis_spi spi0.0: 2.0 TPM (device-id 0x1B, rev-id 22)
[ 1.806754] tpm tpm0: A TPM error (256) occurred continue selftest
test tpm error
$ eltt2 -t
Error opening the device.
Unexpected error: 0x0000000D
I upgraded to JETPACK SDK 5.0.1
root@user-desktop:/home/user# dmesg | grep tpm
[ 7.923214] gpio-313 (tpm-rst-pin): hogged as output/high
but in JETPACK SDK 4.6.1
Why are the GPIO tpm-rst-pin numbers different ???
Could be the gpio base is different for these two release.
sudo cat /sys/kernel/debug/pinctrl/2430000.pinmux/gpio-ranges
tpm-rst-pin {
gpio-hog;
//GPIO8 GPIO3_PBB.00
gpios = <TEGRA194_AON_GPIO(BB, 0) GPIO_ACTIVE_HIGH>;
label = "tpm-rst-pin";
output-high;
status = "okay";
JETPACK SDK 5.0.1
GPIO ranges handled:
167: tegra194-gpio GPIOS [502 - 502] PINS {197}
168: tegra194-gpio GPIOS [503 - 503] PINS {198}
cat /sys/kernel/debug/gpio
gpiochip2: GPIOs 305-334, parent: platform/c2f0000.gpio, tegra194-gpio-aon:
gpio-312 (PAA.07 )
gpio-313 (PBB.00 )
JETPACK SDK 4.6.1
0: tegra-gpio GPIOS [288 - 495] PINS [0 - 207]
208: tegra-gpio GPIOS [496 - 511] PINS [248 - 263]
0: tegra-gpio-aon GPIOS [248 - 287] PINS [208 - 247]
gpiochip1: GPIOs 248-287, parent: platform/c2f0000.gpio, tegra-gpio-aon:
gpio-256 (GPIO8 |tpm-rst-pin ) out hi
It seems that there is a change in the GPIO number definition
But it should still control the same pin
Strange problem now
After 4.6.1 upgrade to 5.0.1
TPM functionality doesn’t seem to work
Can’t see device… neither spi nor tpm drivers are working
Did you configure the SPI PINS. Have you check SPI loopback test?
Some doubts about tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
It seems that these files must be modified together when modifying pinmux
./bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
./bootloader/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
./sources/hardware/nvidia/platform/t19x/galen/bct/pinmux/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
What are the differences between these files??
The ./bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg should be the correct one to modify.
The ./bootloader/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg shouldn’t exit.
You can modify from the source and replace the ./bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg or just modify it directly.
system
Closed
July 13, 2022, 5:36am
#15
