3.The problem is as follows: I am using CSI0 to connect to the camera IMX219-15PIN. After running the command (sudo Nvgstcapture-1.0), a black box appears without any image inside. So I would like to ask, what is the reason for this? Does the system need to open CS0 internally to use it?
What is the operation process? Could you provide some guidance.
Hello:
The information you provided is extensive and disorganized, and much of it does not align with my actual situation.
for example
The version number is different from my system, as shown below, it is JP-5.1.3.
Could you please tell me the detailed steps? Or could you send some reference materials? Thank you very much.
I have previously debugged UART and SPI, and I found that once the device tree is changed, Jetson-IO fails to start. Is there any good way to avoid this?
Hi @403199668 from your logs it looks like the driver has done probe to the sensor on I2C bus 9. Can you check if v4l2-ctl capture is working?
v4l2-ctl -d /dev/video0 –set-fmt-video=width=1920,height=1080,pixelformat=RG10 –stream-mmap -c sensor_mode=2 -c bypass_enable=0 -c override_enable=1 ---verbose
You can also check dmesg while capturing with v4l2-ctl to see if there is any error showing.
Does nvgstcapture-1.0 stills shows dark image? also argus journal might provide some information while nvgstcapture-1.0 is running:
Okay, I’ll try it later. I have temporarily restored the device tree file.
Jetson-io has been launched.
Teacher, please guide me in debugging the camera.
Okay, I understand. What you said must be more accurate than mine. You are a professional.
In addition, I am the HW designer. I led the team to complete the schematic design of this board, PCB board drawing, MCU program writing, system configuration, and low-level program writing. I participated in every step of the process.
I have a better understanding of hardware than software. If you have any ideas, feel free to guide me directly.
Okay, I’ll check it again. The schematic diagram is at the top of this post.
I repeatedly checked this schematic at the beginning of its design. The differential impedance values of the PCB were also tested by Jialichuang, and they are all within 10%.
Let me review it again.
