How to enable driver API?
I wanted to use page-locked memory for my project, which I need cuMemAllocHost to do.
As I understand it, I would need to first call cuInit(0);
However, VC++ complains when I try to compile, saying the functions don’t exist. My project works fine when I don’t use pagelocked memory and thus never needed to use the driver API. However, I wanted to try speeding up CPU to GPU memory transfers.
 cuInit(0);
  cuMemAllocHost((void**)h_idata, TEST_MEM_SIZE);
The Error:
1>------ Build started: Project: md5, Configuration: Release Win32 ------
1>Performing Custom Build Step
1>“main.cu”, line 110: error: identifier “cuInit” is undefined
1> cuInit(0);
1> ^
1>“main.cu”, line 111: error: identifier “cuMemAllocHost” is undefined
1> cuMemAllocHost((void**)h_idata, (2048 * ( 20 * 4096 )));
1> ^
1>2 errors detected in the compilation…
It must be some dumb configuration thing that I’m doing, but I can’t figure it out. Can anyone help me?
Much obliged.
You can use cudaMallocHost and cudaFreeHost from the high-level API.
Alternatively, you can #include the cuda.h, and initialize the driver by cudaMalloc some memory and immediately cudaFree.
