Hi, There
I’m using a device tree similar for leopard image imx185 but my camera module does not have on board 1v2 so I’m using tx1’s which is defined in tegra210-jetson-cv-power-tree-p2597-2180-a00.dtsi
en_vdd_cam_1v2: regulator@209 {
compatible = “regulator-fixed-sync”;
reg = <209>;
regulator-name = “en-vdd-cam-1v2”;
gpio = <&tca9539_77 3 1>;
enable-active-high;
in my camera dt file
dvdd-supply = <&en_vdd_cam_1v2>;
however in the after boot I cannot communicate with my camera’s i2c and after measure it’s core vdd I found there is no voltage.
and in the kernal log I found below
en-vdd-cam-1v2: ; Rail OFF
en-vdd-cam-1v2: disabling
does anybody know what disable the 1v2 vdd?
BTW, I noticed both jetson TX1 devkit camera module and leopard image imx185/172 module provide their own 1v2 instead of using TX1 gpio provided 1v2, is there some specific reason we need to do that?
thanks
xiaoyong
