1: Jetpack4.6_R32.6.1 with Jetson XAVIER NX SOM in our customed board, es8316 is worked.
2: Jetpack4.6_R32.6.1 with Jetson TX2 NX SOM in our customed board, es8316 is not worked.
3: With the same es8316 driver files, after change devicetree file for TX2 NX which reference XAVIER NX, it seem to into rt565x driver rather than es8316.
The guide provides debug depending on the issue. You may need to check various things per guide and provide necessary inputs to rootcause issue further
Also, new codec porting guide is available at link so that you get an idea of the dts/driver changes to be made. Kindly ensure that all of the necessary changes are made
1: dmesg show: codec dai es8316-hifi not regisetered. dmesg.log (68.6 KB)
according the link and dmesg log may be i2c or i2s configuration parameters is not suitable.
addition: kernel/kernel4.9/sound/soc/soc-core.c, debug find error in snd_soc_find_dai function.
1023 /* Find CODEC from registered CODECs */
1024 codec_dais = rtd->codec_dais;
1025 for (i = 0; i < rtd->num_codecs; i++) {
1026 codec_dais[i] = snd_soc_find_dai(&codecs[i]);
1027 if (!codec_dais[i]) {
1028 dev_err(card->dev, "ASoC: CODEC DAI %s not registered\n",
1029 codecs[i].dai_name);
1030 goto _err_defer;
1031 }
1032 }
2: I change tegra186-p3636-0001-common.dtsi and tegra186-p3636-0001-a00-audio.dtsi file show in temp.txt temp.txt (6.1 KB)
Yes. If you refer link, i2c table in Populate Codec Node for TX2 mentions i2c address to be used on 40 pin header as 0xc240000. Pls edit your DT suitably and let us know if the codec dai registration is rectified. After codec dai registration you should be able to see your codec name at cat /sys/kernel/debug/asoc/codecs
Hoping that you have enabled the driver as well. This troubleshooting section has mentioned regarding this
Could you help me check whether i2c@c240000 and i2s@2901000 is suitable for tx2 nx ?
yes I2S on 40 pin header is 0x02901000 and i2c is at 0xc240000
Regarding pinmux, suggest you to avoid doing it from DT. you can do via Jetson-IO tool.
Link for same is here. Pasting command lines here for easy reference
4.Not sure how to interpret the data provided, Instead could you check i2cdetect -y -r <i2c-bus-number>. This will show if the codec is available at desired address
/proc/asounc/cards result means es8316 driver load successful. But at that time, aud_mclk have no signal.
2: After sudo /opt/nvidia/jetson-io/config-by-function.py -o dtb i2s1 aud_mclk, tx2 nx can`t reboot, it stop on the boot screen(this problem I have report, but only get suggestion upgrade Jetpack, but now we have to use JP4.6 version).
