Hi everyone,
Iโm working on securing my Jetson Orin Nano by encrypting the root filesystem using LUKS. However, my requirements differ from the standard OP-TEE-based setup, and I would greatly appreciate clarification and official guidance.
๐ My goal:
I want to encrypt the rootfs with LUKS and require a user to enter a passphrase manually at boot, similar to standard LUKS full-disk encryption on a typical Linux system.
This is important to retain developer flexibility, avoid locking the device with fuses, and allow the Jetson to be reused for other projects or testing purposes.
๐ซ I explicitly do not want to use:
- Any key burned into fuses
โ I want:
- A manual passphrase prompt at boot time
What Iโve done so far:
I generated the base image using:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --network usb0 --no-flash --showlogs \ -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" \ jetson-orin-nano-devkit internal -
Then, I tried preparing a flash with encrypted rootfs using:
sudo ROOTFS_ENC=1 ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs --no-flash \ --external-device nvme0n1 \ -i ./sym2_t234.key \ -c ./tools/kernel_flash/flash_l4t_t234_nvme_rootfs_enc.xml \ -S 800GiB \ --external-only --append \ jetson-orin-nano-devkit external -
I attempted flashing using:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs --flash-only -
Afterward, I tried adding my own passphrase to the LUKS partition with the idea of modifying the initrd to support manual decryption โ but it seems the system does not recognize my
sym2_t234.keywhen I try to reuse or override it.
โMy questions:
If modifying the
initrdis required, are there any detailed NVIDIA-provided guidelines on how to do this properly? -
Is it officially supported to prepare a rootfs encrypted via
cryptsetup luksFormatmanually and integrate it withl4t_initrd_flash.sh? -
The current documentation at Jetson Disk Encryption Guide lacks clarity on the exact procedure for this use case โ is there a reference configuration or best practice you can point me to?
Thanks in advance for your help!
