How to enable PCIe relaxed ordering for GPU Direct RDMA p2p load stores?
PCIe relaxed ordering is a mode in which the strict execution order of TLPs is relaxed. This mode has benefits for high throughput applications. This page indicates that Nvidia GPUs can enable relaxed ordering:
How can this setting be enabled?
Hi @ryan.walton
For Linux Systems
To enable PCIe relaxed ordering on Linux, you can use the kernel module parameter system:
1. Temporary enabling (until next reboot):
sudo modprobe -r nvidia  # Remove the current module if loaded
sudo modprobe nvidia NVreg_SetPCIERelaxedOrdering=1  # Enable
  1. Permanent enabling (persists across reboots):
    Create a configuration file in /etc/modprobe.d/:
echo "options nvidia NVreg_SetPCIERelaxedOrdering=1" | sudo tee /etc/modprobe.d/nvidia-relaxed-ordering.conf
  1. To force-enable regardless of topology compatibility:
echo "options nvidia NVreg_SetPCIERelaxedOrdering=2" | sudo tee /etc/modprobe.d/nvidia-relaxed-ordering.conf
Verifying the Setting
You can verify if relaxed ordering is enabled by using the lspci command:
sudo lspci -vv | grep -i "RlxdOrd"
If relaxed ordering is enabled, you should see RlxdOrd+ in the output. If disabled, you’ll see RlxdOrd-.
