How to enable UART7 (D8, D5) as normal UART like other UART (uartc@C280000)
Hi JerryChang,
I try to change status = “disable” to “okay” in tegra186-soc-uart.dtsi.
And also try to add the following codes in tegra186-quill-p3310-c03-00-base.dts
serial@c290000{
   compatible = "nvidia, tegra186-hsuart"
   status = "okay"
Both ways are failed to add uart port.
I also try to add the other serial (serial@3140000) in tegra186-quill-p3310-c03-00-base.dts and ttyTHS4 is added successfully.
Please check the log.
serial@3140000{
   status = "okay"
serial@3150000 has the same issue to serial@c290000(uart7/uartg) so I think serial@3150000 and serial@c290000(uart7/uartg) should be occupied by other functions.
PS: I can’t find any information in doc for uartf (serial@3150000) but it doesn’t matter.
uart_1211.log (90.5 KB)
hello JasonFan,
had you compile the device tree correctly?
i’m able to saw the UART7 device is added successfully just by changing the DT status,
share the diff for your reference.
--- a/kernel-dts/t18x-common-platforms/tegra186-quill-common.dtsi
+++ b/kernel-dts/t18x-common-platforms/tegra186-quill-common.dtsi
@@ -56,6 +56,11 @@
                status = "okay";
+       serial@c290000 {
+               compatible = "nvidia,tegra186-hsuart";
+               status = "okay";
before,
serial@c290000 {
		#stream-id-cells = <0x1>;
		reg = <0x0 0xc290000 0x0 0x40>;
		reg-shift = <0x2>;
		interrupts = <0x0 0x76 0x4>;
		nvidia,memory-clients = <0xe>;
		dmas = <0x19 0x2 0x19 0x2>;
		dma-names = "rx", "tx";
		clocks = <0xd 0xd8 0xd 0x10d>;
		clock-names = "serial", "parent";
		resets = <0xd 0x70>;
		reset-names = "serial";
		status = "disabled";
		nvidia,adjust-baud-rates = <0x1c200 0x1c200 0x64>;
		linux,phandle = <0x89>;
		phandle = <0x89>;
after,
serial@c290000 {
		reg-shift = <0x2>;
		status = "okay";
		phandle = <0x89>;
Hi JerryChang,
I can make sure I compile the dtb and update correctly because I can add serial@3140000 successfully.
I found we have different source base.
In my “kernel-dts/t18x-common-platforms/tegra186-quill-common.dtsi”, I don’t have serial@c290000{…
Previously, I only add the following codes in tegra186-quill-common.dtsi but got failure
serial@c290000{
   status = "okay"
Now I add all codes you show in previous post in tegra186-quill-common.dtsi but still got “serial-tegra c290000.serial: Failed to add uart port, err -22”
serial@c290000 {
		reg-shift = <0x2>;
		status = "okay";
		phandle = <0x89>;
Is anything I miss or does nVidia has new release for TX2?
Thank you
hello JasonFan,
we’re able to reproduce the serial-tegra c290000.serial: Failed to add uart port, err -22 from our side.
will look into this and get back to you.
thanks
hello JasonFan,
confirmed we had fix “serial-tegra c290000.serial: Failed to add uart port, err -22” issue.
the fix will be include in the next JetPack release.
thanks
hello JasonFan,
confirmed we had included the uart failure fix in JetPack-3.2 DP
[url]https://developer.nvidia.com/embedded/downloads#?search=jetpack%203.2[/url]
please have a development with this JetPack release.
thanks
Hi JerryChang,
I’ll try it. Thank you
hello JasonFan,
may i have your status update,
is this still an issue with JetPack-3.2 DP ?
thanks
Hi JerryCHang,
I have downloaded R28.2 but will not move r28.1 to r28.2 soon.
You can close this issue first.
Thank you
Hi JerryChang,
Can you post the patch(es) needed to the R28.1 device tree sources to solve this issue:
I’d like to use UART7 without upgrading (yet) to 28.2.
Cheers,
Morgan
Hi morganziy3j,
There are relevant changes required to make it work, please move to 28.2 directly.
Thanks kayccc, I just upgraded to 28.2, and by modifying the device tree it is possible to get UART7 to show up as /dev/ttyTHS6. However, as noted in another thread, there is some other traffic on that UART which seems to make it difficult/impossible to use for a custom application:
It seems that sometimes that other controller responds with error messages to traffic on that UART, which get interleaved with our traffic, and therefore UART7 is not really usable for bidirectional communications… though I suppose maybe some unidirectional use cases might find a use for it.
Is there some way to tell that “other” (internal) device on UART7 to “stop talking”?
Cheers
hello morganziy3j,
since you’re able to get UART7 works with R28.2 DP.
could you please file another new topic with appropriate subjects and let us track specific issue there.
thanks
Thanks, I apologize for changing the topic of this thread; I agree that we can mark this thread’s issue as resolved, since UART7 is working now in R28.2 DP. I will create another thread with my follow-up question. Cheers
Does the UART7 can use as a common serial port now ?
Hello!
I’m use my custom carrier board for Jetson TX2 and I have enable UART7 (D5, D8 pins).
In DTS I apply this changes:
serial@c290000 {
status = “okay”;
but UART7 don’t work, in dmesg I see:
I’m use R28.2.1 DP. That do need for UART7 steel working?
Thanks in advance.
Problem may be solved by this way:
in file: /sources/kernel/kernel-4.4/drivers/tty/serial/serial-tegra.c
need change : #define TEGRA_UART_MAXIMUM 5
to: #define TEGRA_UART_MAXIMUM 7
After that ttyTHS6 added and work fine!
Yes, after change define in sources and change tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb in this place: (after decompiling)
serial {
port = <0xff>; #port = <0x7>;
has_input;
and load flash:
sudo ./flash.sh jetson-tx2 mmcblk0p1
UART7 work fine! Can check transmit:
echo “123456” > /dev/ttyTHS6
and recive:
cat -v < /dev/ttyTHS6
then type in terminal (I’m use Putty) any characters.
I’m use Tegra186_Linux_R28.2.1_aarch64
Hi ksv198:
 I still get some strange info when doing loop testing
OPTIONS: I18n
Compiled on Feb  7 2016, 13:35:57.
Port /dev/ttyTHS6, 03:04:48
Press CTRL-A Z for help on special keys
f
error: line too long
command not found
command not found
command not found
command not found
Here is what I had done
1 First, I use
JetPack-L4T-3.3-linux-x64_b39.run
to flash a new image to the TX2 with official board;
2 Then, convert the DTB to DTS using dtc tool in Linux_for_Tegra with the dtb file
tegra186-quill-p3310-1000-c03-00-base.dtb
, modify the
serial@c290000 {
status = "okay";
Then rebuild the dtb file and flash to the TX2;
3 Third, to ensure the
I rebuild the kernel.
4 Last I find the ttyTHS6 in /dev/, I short circuit the UART4_RX and UART4_TX in the office board, and done test, but get wrong messages.
What other things I should do?
