hello JasonFan,
confirmed we had included the uart failure fix in JetPack-3.2 DP
[url]https://developer.nvidia.com/embedded/downloads#?search=jetpack%203.2[/url]
please have a development with this JetPack release.
thanks
hello JasonFan,
thanks
Hi JerryChang,
Iāll try it. Thank you
hello JasonFan,
may i have your status update,
is this still an issue with JetPack-3.2 DP ?
thanks
Hi JerryCHang,
I have downloaded R28.2 but will not move r28.1 to r28.2 soon.
You can close this issue first.
Thank you
Hi JerryChang,
Can you post the patch(es) needed to the R28.1 device tree sources to solve this issue:
serial-tegra c290000.serial: Failed to add uart port, err -22
Iād like to use UART7 without upgrading (yet) to 28.2.
Cheers,
Morgan
Hi morganziy3j,
There are relevant changes required to make it work, please move to 28.2 directly.
Thanks kayccc, I just upgraded to 28.2, and by modifying the device tree it is possible to get UART7 to show up as /dev/ttyTHS6. However, as noted in another thread, there is some other traffic on that UART which seems to make it difficult/impossible to use for a custom application:
It seems that sometimes that other controller responds with error messages to traffic on that UART, which get interleaved with our traffic, and therefore UART7 is not really usable for bidirectional communicationsā¦ though I suppose maybe some unidirectional use cases might find a use for it.
Is there some way to tell that āotherā (internal) device on UART7 to āstop talkingā?
Cheers
hello morganziy3j,
since youāre able to get UART7 works with R28.2 DP.
could you please file another new topic with appropriate subjects and let us track specific issue there.
thanks
Thanks, I apologize for changing the topic of this thread; I agree that we can mark this threadās issue as resolved, since UART7 is working now in R28.2 DP. I will create another thread with my follow-up question. Cheers
Does the UART7 can use as a common serial port now ?
Hello!
Iām use my custom carrier board for Jetson TX2 and I have enable UART7 (D5, D8 pins).
In DTS I apply this changes:
serial@c290000 {
ā¦
status = āokayā;
but UART7 donāt work, in dmesg I see:
Iām use R28.2.1 DP. That do need for UART7 steel working?
Thanks in advance.
Problem may be solved by this way:
in file: /sources/kernel/kernel-4.4/drivers/tty/serial/serial-tegra.c
need change : #define TEGRA_UART_MAXIMUM 5
to: #define TEGRA_UART_MAXIMUM 7
After that ttyTHS6 added and work fine!
Yes, after change define in sources and change tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb in this place: (after decompiling)
serial {
port = <0xff>; port = <0x7>;
has_input;
and load flash:
sudo ./flash.sh jetson-tx2 mmcblk0p1
UART7 work fine! Can check transmit:
echo ā123456ā > /dev/ttyTHS6
and recive:
cat -v < /dev/ttyTHS6
then type in terminal (Iām use Putty) any characters.
Iām use Tegra186_Linux_R28.2.1_aarch64
Hi ksv198:
I still get some strange info when doing loop testing
OPTIONS: I18n
Compiled on Feb 7 2016, 13:35:57.
Port /dev/ttyTHS6, 03:04:48
Press CTRL-A Z for help on special keys
f
error: line too long
command not found
command not found
command not found
command not found
Here is what I had done
1 First, I use
JetPack-L4T-3.3-linux-x64_b39.run
to flash a new image to the TX2 with official board;
2 Then, convert the DTB to DTS using dtc tool in Linux_for_Tegra with the dtb file
tegra186-quill-p3310-1000-c03-00-base.dtb
, modify the
serial@c290000 {
status = "okay";
Then rebuild the dtb file and flash to the TX2;
3 Third, to ensure the
I rebuild the kernel.
4 Last I find the ttyTHS6 in /dev/, I short circuit the UART4_RX and UART4_TX in the office board, and done test, but get wrong messages.
What other things I should do?
I recommend testing under gtkterm. An example command line for 115200 8N1 to ttyTHS6 on a TX2:
# Use "sudo" if your user isn't a member of group "dialout".
gtkterm -b 8 -t 1 -s 115200 -p /dev/ttyTHS6
Minicom was designed to initialize modems using the AT command set. Gtkterm is simpler if you arenāt using a modem.
The result is same as the minicom!!!
Hello!
I think you need disconnect uart7 from internal debugger.
See thread: Internal TX2 traffic on UART7 ? - Jetson TX2 - NVIDIA Developer Forums
You need decompile tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb and change this:
serial {
has_input;
then compile, run apply_binaries.sh and flash:
Good luck!
Yes, I make it, thanks!
I make it, thanks!
