How to enable USB2-2 on Xavier NX
We should use2-2 port for LTE Module.
Our LTE Module has USB to serial port.
So, we just connect it with USB port from Xavier NX Module.
I tried next things :
  1. tegra194-p3668-common.dtsi (11.7 KB)
  2. \kernel\kernel-4.9\drivers\usb\serial\option.c => option.c (125.1 KB)
    Added in option.c :
   /* AMTelecom products */
   #define AMTEL_VENDOR_ID                               0x1ECB
   #define AMTEL_PRODUCT_ID                              0x0205
   { USB_DEVICE(AMTEL_VENDOR_ID, AMTEL_PRODUCT_ID) },                         /* AMTelcom AMM574 */
But it doesn’t work.
And this is the log file. => log.txt (7.6 KB)
Please, check it.
We have guidance for hardware design and software pogramming. For hardware design, please check:
https://developer.nvidia.com/jetson-xavier-nx-product-design-guide
USB2-2 is pin # 121 and 123.
For software programming, please check adaptation guide
It was kernel build issue.
I’ve got device node from usb2-2.
