We are using the ubuntu OS with the Jetson-TX2 wifi function,the 2.4GHz can be used, but 5GHz does not work, how to enable 5GHz function?
Hi Bryan,
The simplest way is the GUI of ubuntu desktop. You could change the wifi channel when you try to create AP.
