I want to encode a frame with different QPs to observe how different QPs influent the output size. But after encoding once, the reference frame changed automatic. Is there a method to control reference frame unchanged? Thank you!
Related topics
Topic | Replies | Views | Activity | |
Change Constant QP value without generating IDR | 5 | 1353 | October 12, 2021 | |
'Qp' and 'reference picture' settings for H265 & H264 encoder | 2 | 1570 | October 18, 2021 | |
Issue changing qp level in CUDA H.264 Encoder between frames | 0 | 1753 | November 13, 2012 | |
Encoder reset | 5 | 1840 | November 13, 2018 | |
Is there any way to disable short term reference frame in NVENC? | 0 | 414 | November 23, 2020 | |
3-frames frame size change delay on bitrate change | 0 | 380 | August 17, 2022 | |
Jetson Nano Encode Frame by Frame | 2 | 524 | October 15, 2021 | |
Force I-Frame / Ensure GOP structure | 3 | 683 | October 18, 2021 | |
NvEnc: Multirate encoding? | 0 | 509 | October 5, 2021 | |
Get frame QP of the last coded frame | 0 | 471 | January 24, 2022 |
