How to enhance decoder performance on T4?
• Hardware Platform (Jetson / GPU) T4
• DeepStream Version 6.2
• TensorRT Version 8.0
• NVIDIA GPU Driver Version (valid for GPU only) 440
• Issue Type( questions, new requirements, bugs) questions
I test the decoder performance on jetson with command
“gst-launch-1.0 rtspsrc location=rtsp://admin:Aa111111@192.168.1.10:554/h264/ch1/main/av_stream latency=0 ! rtph264depay ! h264parse ! nvv4l2decoder disable-pdb=true ! nvvideoconvert ! video/x-raw,width=1280,height=720,format=BGRx ! videoconvert ! ximagesink”,
and the latency is around 100ms.
But when I test the decoder performance on T4 with similar command
“gst-launch-1.0 rtspsrc location=rtsp://admin:Aa111111@192.168.1.10:554/h264/ch1/main/av_stream latency=0 ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvideoconvert ! video/x-raw,width=1280,height=720,format=BGRx ! videoconvert ! ximagesink”,
and the latency is 200-800ms because of without property disable-pdb=true
So how to enhance the decoder performance on T4?
How did you measure the latency of the pipeline?
I compare the timestamp in the command and this record in the picture.
Do you mean you measure the latency between the RTSP server and the display on screen?
not the RTSP server. It is timestamp printed on command line and I record it with camera.
I compare the timestamp when I get the image and the timestamp record in the image.
What kind of timestamp? PTS of the GstBuffer?
the timestamp like this:
#!/bin/bash
while true
do
timestamp=$(date +%s%3N)
echo “$timestamp”
done
It is the local time, where did you print the time?
the command line.
What command line? Can you elaborate the exact methods you calculate the latency?
