Now, we flash OS follow NV doc by press Recovery+Power, For Ramp build, we hope:
solution 1: We want to automate the OS flashing via USB, eliminating the need for manual intervention, such as pressing the (Recovery + Power) buttons.
solution 2: The OS will be pre-cloned to the SSD, so during Ramp build, we simply install the SSD to complete the setup.
Please give me some guidance. Thank you.
Hi, you can run this on the board to reboot into recovery mode:
sudo reboot --force forced-recovery
But that assumes the board already has something flashed and you can log into it.
Hi, Miguel Taylor,
Thank you for your reply. There should be an automated flash method, maybe need additional equipment to support this.
update command: sudo reboot forced-recovery (verify on AGX orin)
Is this still an issue to support?
Could we close the topics?
