You would break your system if you forced these to install. They are as @b-sathishkumar mentioned different hardware architectures.
i386 is 32-bit PC. amd64 is 64-bit PC. armhf is 32-bit ARM with the E-ABI hardfloat option. Your system is 64-bit ARM (arm64/aarch64).
You could use an emulator/VM for this (performance would not be great).
It is worth noting that the 64-bit ARM CPUs have a 32-bit emulation mode which is a superset of the armhf. That superset is the 32-bit ARM with all optional extensions (naming the extension when using this breaks the program since on actual 32-bit ARM this is optional, but on compatibility mode 64-it ARM this is not an option, it is mandatory). The performance in this mode is terrible, but ignoring that, installing all of the needed user space libraries and linkers is itself a daunting task in comparison to using an emulator. Emulators themselves are not easy, and you would still need to install all of the linkers and libraries (but they wouldn’t interfere with the 64-bit system).
Really, the best bet, is if you can get the programs you are working with compiled for 64-bit ARM. If you have the source, but not the binaries, then you can quite often do so without too much pain. If it is an interpreted program, e.g., Python or Perl, then it wouldn’t be i386 or amd64, and would instead be “noarch”, so you already know the programs in question are compiled.
Incidentally, libc (in this case libc6 version) is the backbone of any *NIX clone, including Linux. This is part of the environment for an entire operating system. If you had a natively compiled version of the program, then it would use the existinglibc6:arm64.
Noted that the best way is to compile the library for arm64. As your advice, I’ve requested the supplier to compile new one. Now, only I can do is to hope they accept my request. Thank you so much!
