How to execute an algorithm in CUDA C from R?....
How to execute an algorithm in CUDA C from R?..Algorithm must be invoked from R, the algorithm will be used for processing satellite images (MODIS), basically to calculate desertification.
I have been reading and everyone says to use an interface function from R to invoke the CUDA function, but in the examples primarily implemented native functions C / C ++ and I just want to run a CUDA code C.
I would appreciate any help!
I think you can refer to the following blog firstly, it introduces the computation model of R with GPU acceleration.
Learn more at http://on-demand.gputechconf.com/gtc/2015/presentation/S5145-Patric-Zhao.pdf
Please let us know if the above article(and slide) helps on your questions. Thanks!
