Please provide the following info (tick the boxes after creating this topic): Software Version
[*] DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] DRIVE AGX Orin Developer Kit (940-63710-0010-100)
other
SDK Manager Version
2.1.0
other
Host Machine Version
[*] native Ubuntu Linux 20.04 Host installed with DRIVE OS Docker Containers
other
Issue Description
I have an external python based application which actually does the Vision processing like reading frames and performing the object detection and annotation. I want to run this application on GPU. Can you please let me know how to execute any custom application on GPU?
If it is just python code which runs sequentially on CPU, there is no way to offload to GPU directly. As clarified earlier, You need to implement the function as CUDA kernel to make it run on GPU.
We have couple of CUDA samples at /usr/local/cuda-11.4/samples for your reference. You can take look at CUDA C++ Programming Guide for details on CUDA programming.
Any specific reason why explicit applications like Python or C/C++ wont be able to access GPU as we have seen on x86 based machines which are having GPU configured; on these systems using below command the python application will run on GPU which does not happen in case of Orin.
Dear @PA_GN,
I am not sure why your application could not run on GPU. but, We have CUDA c++ samples and TRT python samples on DRIVE OS which can run on GPU.
Dear @PA_GN ,
Please see /usr/src/tensorrt/samples/python for TRT python samples.
Please check ReadMe file for each sample for requirements and guidance. In case of any issue, please file new topic with all details.
