I am just wondering if there is information on how to run the classify many from the terminal within the container and save outputs as csv/txt file.
I have found a kind of a solution at the github thread
# create csv files and write names and probs there
dump_csv = open('/home/ubuntu/results.csv', 'w')
dump_csv.write('Path\tProbabilities')
for i,j in zip(paths, scores):
newline = i + '\t' + str(j) + '\n'
dump_csv.write(newline)
dump_csv.close()
but it is said to add the sequence above to the views.py file and there are several:
sudo locate views.py |grep classification
/var/lib/docker/overlay2/452ef113e5f0413699e374601c8d8ea14fcdc6ccb68223a54026e799c635dfa0/diff/opt/digits/digits/dataset/images/classification/test_views.py
/var/lib/docker/overlay2/452ef113e5f0413699e374601c8d8ea14fcdc6ccb68223a54026e799c635dfa0/diff/opt/digits/digits/dataset/images/classification/views.py
/var/lib/docker/overlay2/452ef113e5f0413699e374601c8d8ea14fcdc6ccb68223a54026e799c635dfa0/diff/opt/digits/digits/model/images/classification/test_views.py
/var/lib/docker/overlay2/452ef113e5f0413699e374601c8d8ea14fcdc6ccb68223a54026e799c635dfa0/diff/opt/digits/digits/model/images/classification/views.py
/var/lib/docker/overlay2/89d8229fa353ad1e906a8ee6d4d57f1bddca22337ec551b51330cadca4dfb2f4/diff/opt/digits/digits/dataset/images/classification/views.pyc
/var/lib/docker/overlay2/89d8229fa353ad1e906a8ee6d4d57f1bddca22337ec551b51330cadca4dfb2f4/diff/opt/digits/digits/model/images/classification/views.pyc
/var/lib/docker/overlay2/89d8229fa353ad1e906a8ee6d4d57f1bddca22337ec551b51330cadca4dfb2f4/merged/opt/digits/digits/dataset/images/classification/test_views.py
/var/lib/docker/overlay2/89d8229fa353ad1e906a8ee6d4d57f1bddca22337ec551b51330cadca4dfb2f4/merged/opt/digits/digits/dataset/images/classification/views.py
/var/lib/docker/overlay2/89d8229fa353ad1e906a8ee6d4d57f1bddca22337ec551b51330cadca4dfb2f4/merged/opt/digits/digits/dataset/images/classification/views.pyc
/var/lib/docker/overlay2/89d8229fa353ad1e906a8ee6d4d57f1bddca22337ec551b51330cadca4dfb2f4/merged/opt/digits/digits/model/images/classification/test_views.py
/var/lib/docker/overlay2/89d8229fa353ad1e906a8ee6d4d57f1bddca22337ec551b51330cadca4dfb2f4/merged/opt/digits/digits/model/images/classification/views.py
/var/lib/docker/overlay2/89d8229fa353ad1e906a8ee6d4d57f1bddca22337ec551b51330cadca4dfb2f4/merged/opt/digits/digits/model/images/classification/views.pyc
nvidia@nvidia-ngc-image-9-vm:~$ sudo locate views.py |grep classification
