• Hardware Platform: GPU
• DeepStream Version: 7.1
• Cuda Version: 12.6
• NVIDIA GPU Driver Version: 560.35.03
• Issue Type: Question
So i am trying to do some inferences in deepstream with python, having a triton inference server.
It’s working, but i don’t know how to get only one specific class from the inference results.
Let’s say my model has 6 classes as output, i only want to get the class number 2.
Thank you in advance!
This is my nvinferserver configuration file
infer_config {
unique_id: 1
gpu_ids: [0]
max_batch_size: 1
backend {
inputs: [ {
outputs: [
{name: "output_bbox/BiasAdd:0"},
{name: "output_cov/Sigmoid:0"}
triton {
model_name: "peoplenet"
version: -1
grpc {
url: "0.0.0.0:8001"
enable_cuda_buffer_sharing: true
preprocess {
network_format: IMAGE_FORMAT_RGB
tensor_order: TENSOR_ORDER_LINEAR
tensor_name: "input_1:0"
maintain_aspect_ratio: 0
frame_scaling_hw: FRAME_SCALING_HW_DEFAULT
frame_scaling_filter: 1
normalize {
scale_factor: 0.0039215697906911373
channel_offsets: [0, 0, 0]
postprocess {
labelfile_path: "/opt/nvidia/deepstream/deepstream-7.1/sources/deepstream_python_apps/apps/myapp/models/peoplenet/1/labels.txt"
detection {
num_detected_classes: 3
per_class_params {
key: 2
value { pre_threshold: 0.4 }
nms {
confidence_threshold:0.2
topk:20
iou_threshold:0.5
extra {
copy_input_to_host_buffers: false
output_buffer_pool_size: 2
input_control {
process_mode: PROCESS_MODE_FULL_FRAME
operate_on_class_ids: [2]
interval: 0
You can add a probe function to the src pad of the nvinferserver element, and then get the specified class in the obj_meta_list. This code snippet from deepstream_test3_app.c
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next) {
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
//int offset = 0;
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
l_obj = l_obj->next) {
obj_meta = (NvDsObjectMeta *) (l_obj->data);
if (obj_meta->class_id == PGIE_CLASS_ID_VEHICLE) {
vehicle_count++;
num_rects++;
if (obj_meta->class_id == PGIE_CLASS_ID_PERSON) {
person_count++;
num_rects++;
Thanks for this idea. I was thinking there is a config parameter like there is filter-out-class-ids in the nvinfer config file that does this for the nvinferserver too.
Something like this
filter-out-class-ids = 0;1;3;4;5;6;7;8;9;10;11;12 ...
Currently not supported,
nvinferserver
is open source, you can add this feature by yourself, you can refer to this patch.
diff --git a/sources/gst-plugins/gst-nvinferserver/gstnvinferserver_meta_utils.cpp b/sources/gst-plugins/gst-nvinferserver/gstnvinferserver_meta_utils.cpp
index d13a005..39c7336 100755
--- a/sources/gst-plugins/gst-nvinferserver/gstnvinferserver_meta_utils.cpp
+++ b/sources/gst-plugins/gst-nvinferserver/gstnvinferserver_meta_utils.cpp
@@ -105,6 +105,11 @@ attachDetectionMetadata(
+ const auto& ids = config.output_control().filter_out_class_ids();
+ if (!ids.empty() &&
+ (std::find(ids.begin(), ids.end(), obj.classIndex) != ids.end()))
+ continue;
/* Scale the bounding boxes proportionally based on how the object/frame
* was scaled during input. */
obj.left = (obj.left - offsetLeft) / scaleX + roiLeft;
diff --git a/sources/gst-plugins/gst-nvinferserver/nvdsinferserver_plugin.proto b/sources/gst-plugins/gst-nvinferserver/nvdsinferserver_plugin.proto
index 3d39caf..3843ec8 100755
--- a/sources/gst-plugins/gst-nvinferserver/nvdsinferserver_plugin.proto
+++ b/sources/gst-plugins/gst-nvinferserver/nvdsinferserver_plugin.proto
@@ -124,6 +124,8 @@ message PluginControl {
/* Classifier type of a particular nvinferserver component. */
string classifier_type = 3;
+ /* Filter specified class IDs */
+ repeated int32 filter_out_class_ids = 4;
# /opt/nvidia/deepstream/deepstream/sources/includes/nvdsinferserver_plugin.proto also needs to be modified
make CUDA_VER=12.6 install
Finally, add this to your application configuration file
output_control {
filter_out_class_ids: [1, 2, 3]
Add to FAQ
43. [DSx_All_App] How to extract specific class on deepstream with nvinferserver
Thank you so much for the solution!
system
Closed
March 18, 2025, 3:12am
8
