How to fetch NvDsTracker shadow tracking data using Python
• DeepStream 7.0
Hi, I am trying to use shadow tracking data generated by the NvTracker plugin from pyds.
In c++, I could do this by retrieving the NVDS_TRACKER_SHADOW_LIST_META type of user_meta.
However, it seems that NVDS_TRACKER_SHADOW_LIST_META enum is not available in the python bindings:
>>> import pyds
>>> dir(pyds.NvDsMetaType)
['NVDSINFER_SEGMENTATION_META', 'NVDSINFER_TENSOR_OUTPUT_META', 'NVDS_AUDIO_BATCH_META', 'NVDS_AUDIO_FRAME_META', 'NVDS_BATCH_META', 'NVDS_CLASSIFIER_META', 'NVDS_CROP_IMAGE_META', 'NVDS_DISPLAY_META', 'NVDS_EVENT_MSG_META', 'NVDS_FORCE32_META', 'NVDS_FRAME_META', 'NVDS_GST_CUSTOM_META', 'NVDS_INVALID_META', 'NVDS_LABEL_INFO_META', 'NVDS_LATENCY_MEASUREMENT_META', 'NVDS_OBJ_META', 'NVDS_OPTICAL_FLOW_META', 'NVDS_PAYLOAD_META', 'NVDS_RESERVED_META', 'NVDS_START_USER_META', 'NVDS_TRACKER_PAST_FRAME_META', 'NVDS_USER_META', '__class__', '__delattr__', '__dir__', '__doc__', '__entries', '__eq__', '__format__', '__ge__', '__getattribute__', '__getstate__', '__gt__', '__hash__', '__index__', '__init__', '__init_subclass__', '__int__', '__le__', '__lt__', '__members__', '__module__', '__ne__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__setstate__', '__sizeof__', '__str__', '__subclasshook__', 'name']
Is the functionality available in Python deepstream bindings to retrieve the shadow tracking data?
You need to add the corresponding bindings. I modified deepstream_test_2.py. You can refer to it.
1.modify pyds
diff --git a/bindings/docstrings/nvdsmetadoc.h b/bindings/docstrings/nvdsmetadoc.h
index bf222a2..7d1c092 100644
--- a/bindings/docstrings/nvdsmetadoc.h
+++ b/bindings/docstrings/nvdsmetadoc.h
@@ -44,6 +44,7 @@ namespace pydsdoc
             constexpr const char* NVDSINFER_SEGMENTATION_META=R"pyds(metadata type of segmentation model output attached by gst-nvinfer. Refer :class:`NvDsInferSegmentationMeta` for details.)pyds";
             constexpr const char* NVDS_CROP_IMAGE_META=R"pyds(Specifies metadata type for JPEG-encoded object crops.See the deepstream-image-meta-test app for details.)pyds";
             constexpr const char* NVDS_TRACKER_PAST_FRAME_META=R"pyds(metadata type to be set for tracking previous frames)pyds";
+            constexpr const char* NVDS_TRACKER_SHADOW_LIST_META=R"pyds(metadata type for Shadow Tracking mode)pyds";
             constexpr const char* NVDS_AUDIO_BATCH_META=R"pyds(Specifies metadata type for formed audio batch.)pyds";
             constexpr const char* NVDS_AUDIO_FRAME_META=R"pyds(Specifies metadata type for audio frame.)pyds";
             constexpr const char* NVDS_RESERVED_META=R"pyds(Reserved field)pyds";
diff --git a/bindings/docstrings/trackermetadoc.h b/bindings/docstrings/trackermetadoc.h
index 4a35840..359c1b2 100644
--- a/bindings/docstrings/trackermetadoc.h
+++ b/bindings/docstrings/trackermetadoc.h
@@ -82,6 +82,15 @@ namespace pydsdoc
             constexpr const char* cast=R"pyds(cast given object/data to :class:`NvDsTargetMiscDataFrame`, call pyds.NvDsTargetMiscDataFrame.cast(data))pyds";
+        namespace TRACKER_STATEDoc {
+            constexpr const char* descr = R"pyds(*Enumerator*, Specifies the data type of TRACKER_STATE.)pyds";
+            constexpr const char* EMPTY = R"pyds(EMPTY)pyds";
+            constexpr const char* ACTIVE = R"pyds(ACTIVE)pyds";
+            constexpr const char* INACTIVE = R"pyds(INACTIVE)pyds";
+            constexpr const char* TENTATIVE = R"pyds(TENTATIVE)pyds";
+            constexpr const char* PROJECTED = R"pyds(PROJECTED)pyds";
         namespace NvDsTargetMiscDataObjectDoc
diff --git a/bindings/src/bindnvdsmeta.cpp b/bindings/src/bindnvdsmeta.cpp
index 95b0585..0793d4e 100644
--- a/bindings/src/bindnvdsmeta.cpp
+++ b/bindings/src/bindnvdsmeta.cpp
@@ -65,6 +65,8 @@ namespace pydeepstream {
                 .value("NVDS_TRACKER_PAST_FRAME_META",
                        NVDS_TRACKER_PAST_FRAME_META,
                        pydsdoc::nvmeta::MetaTypeDoc::NVDS_TRACKER_PAST_FRAME_META)
+                .value("NVDS_TRACKER_SHADOW_LIST_META",
+                       NVDS_TRACKER_SHADOW_LIST_META, pydsdoc::nvmeta::MetaTypeDoc::NVDS_TRACKER_SHADOW_LIST_META)
                 .value("NVDS_AUDIO_BATCH_META", NVDS_AUDIO_BATCH_META,
                        pydsdoc::nvmeta::MetaTypeDoc::NVDS_AUDIO_BATCH_META)
                 .value("NVDS_AUDIO_FRAME_META", NVDS_AUDIO_FRAME_META,
diff --git a/bindings/src/bindtrackermeta.cpp b/bindings/src/bindtrackermeta.cpp
index 672e7bb..01d6b7c 100644
--- a/bindings/src/bindtrackermeta.cpp
+++ b/bindings/src/bindtrackermeta.cpp
@@ -25,6 +25,20 @@ namespace py = pybind11;
     void bindtrackermeta(py::module &m) {
+        py::enum_<TRACKER_STATE>(m, "TRACKER_STATE",
+                                     pydsdoc::trackerdoc::TRACKER_STATEDoc::descr)
+                .value("EMPTY", EMPTY,
+                       pydsdoc::trackerdoc::TRACKER_STATEDoc::EMPTY)
+                .value("ACTIVE", ACTIVE,
+                       pydsdoc::trackerdoc::TRACKER_STATEDoc::ACTIVE)
+                .value("INACTIVE", INACTIVE,
+                       pydsdoc::trackerdoc::TRACKER_STATEDoc::INACTIVE)
+                .value("TENTATIVE", TENTATIVE,
+                       pydsdoc::trackerdoc::TRACKER_STATEDoc::TENTATIVE)
+                .value("PROJECTED", PROJECTED,
+                       pydsdoc::trackerdoc::TRACKER_STATEDoc::PROJECTED)
+                .export_values();
         /*Start of Bindings for nvds_tracker_meta.h*/
         py::class_<NvDsTargetMiscDataFrame>(m, "NvDsTargetMiscDataFrame",
                                      pydsdoc::trackerdoc::NvDsTargetMiscDataFrameDoc::descr)
@@ -33,6 +47,8 @@ namespace pydeepstream {
                 .def_readwrite("tBbox", &NvDsTargetMiscDataFrame::tBbox)
                 .def_readwrite("confidence", &NvDsTargetMiscDataFrame::confidence)
                 .def_readwrite("age", &NvDsTargetMiscDataFrame::age)
+                .def_readwrite("trackerState", &NvDsTargetMiscDataFrame::trackerState)
+                .def_readwrite("visibility", &NvDsTargetMiscDataFrame::visibility)
                 .def("cast",
                      [](void *data) {
I tested it on jetson, the dGPU is the same
cd /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/build
make
pip uninstall pyds
pip3 install ./pyds-1.1.11-py3-none-linux_aarch64.whl
2.This is patch of deepstream_test_2.py and config_tracker_NvDCF_perf.yml
diff --git a/apps/deepstream-test2/config_tracker_NvDCF_perf.yml b/apps/deepstream-test2/config_tracker_NvDCF_perf.yml
index 394f04d..18ec39d 100644
--- a/apps/deepstream-test2/config_tracker_NvDCF_perf.yml
+++ b/apps/deepstream-test2/config_tracker_NvDCF_perf.yml
@@ -29,6 +29,7 @@ TargetManagement:
   probationAge: 3 # If the target's age exceeds this, the target will be considered to be valid.
   maxShadowTrackingAge: 30  # Max length of shadow tracking. If the shadowTrackingAge exceeds this limit, the tracker will be terminated.
   earlyTerminationAge: 1   # If the shadowTrackingAge reaches this threshold while in TENTATIVE period, the target will be terminated prematurely.
+  outputShadowTracks: 1
 TrajectoryManagement:
   useUniqueID: 0   # Use 64-bit long Unique ID when assignining tracker ID. Default is [true]
diff --git a/apps/deepstream-test2/deepstream_test_2.py b/apps/deepstream-test2/deepstream_test_2.py
index f787a7f..00d6d96 100755
--- a/apps/deepstream-test2/deepstream_test_2.py
+++ b/apps/deepstream-test2/deepstream_test_2.py
@@ -128,7 +128,7 @@ def osd_sink_pad_buffer_probe(pad,info,u_data):
             user_meta=pyds.NvDsUserMeta.cast(l_user.data)
         except StopIteration:
             break
-        if(user_meta and user_meta.base_meta.meta_type==pyds.NvDsMetaType.NVDS_TRACKER_PAST_FRAME_META):
+        if (user_meta and user_meta.base_meta.meta_type == pyds.NvDsMetaType.NVDS_TRACKER_SHADOW_LIST_META):
             try:
                 # Note that user_meta.user_meta_data needs a cast to pyds.NvDsTargetMiscDataBatch
                 # The casting is done by pyds.NvDsTargetMiscDataBatch.cast()
@@ -145,7 +145,6 @@ def osd_sink_pad_buffer_probe(pad,info,u_data):
                     print("numobj=",miscDataObj.numObj)
                     print("uniqueId=",miscDataObj.uniqueId)
                     print("classId=",miscDataObj.classId)
-                    print("objLabel=",miscDataObj.objLabel)
                     for miscDataFrame in pyds.NvDsTargetMiscDataObject.list(miscDataObj):
                         print('frameNum:', miscDataFrame.frameNum)
                         print('tBbox.left:', miscDataFrame.tBbox.left)
@@ -153,7 +152,8 @@ def osd_sink_pad_buffer_probe(pad,info,u_data):
                         print('tBbox.top:', miscDataFrame.tBbox.top)
                         print('tBbox.right:', miscDataFrame.tBbox.height)
                         print('confidence:', miscDataFrame.confidence)
-                        print('age:', miscDataFrame.age)
+                        print('trackerState:', miscDataFrame.trackerState)
+                        print('visibility:', miscDataFrame.visibility)
         try:
             l_user=l_user.next
  1. Run the sample.
python3 deepstream_test_2.py /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264
Similar results will be output to the terminal
numobj= 1
uniqueId= 20
classId= 0
frameNum: 30
tBbox.left: 806.1800537109375
tBbox.width: 27.789276123046875
tBbox.top: 462.8977355957031
tBbox.right: 17.30149269104004
confidence: 0.5567905902862549
trackerState: TRACKER_STATE.INACTIVE
visibility: 1.0
