How to find the guide for yml configuration?
rtx 2060
• DeepStream Version
deepstream 7.0
• TensorRT Version
with deepstream7.0 docker image
535
questions
I have been using the old version of deepstream, which uses txt as the configuration file. The new version seems to be able to use yml as the configuration file at the same time, but I don’t understand its detailed usage documentation. How should I create a yml file? Is it recommended to only use graph composer? How can I get the configuration guide in the yml file? I only found this document Overview — DeepStream documentation 6.4 documentation, but there are basically no details. How can I find the relevant instructions?
All the parameters in YAML configuration are exactly the same as in the txt configuration file. There are already lots of sample YAML configuration file samples in the SDK. You can generate your own YAML configuration files by referring to the sample YAML files.
