How to find the size of the class_map in NvDsInferSegmentationMeta?
The NvDsInferSegmentationMeta populated during inference on segmentation models has the class_map member which is a pointer to the array for 2D pixel class map. How do I find the size of this array without having to iterate through it? Is there a formula used during allocation based on the width and height members maybe?
• DeepStream Version
• TensorRT Version
• Hardware Platform (Jetson / GPU) Jetson Xavier
• DeepStream Version: 6.1
I don’t think the other setup details should be relevant here because I am asking about the NvDsInferSegmentationMeta.
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one.
please refer to the code in pgie_src_pad_buffer_probe of opt\nvidia\deepstream\deepstream\sources\apps\sample_apps\deepstream-preprocess-test\deepstream_preprocess_test.cpp
        NvDsInferSegmentationMeta *segmeta = (NvDsInferSegmentationMeta *)(user_meta->user_meta_data);
        std::vector<float> temp(segmeta->width * segmeta->height);
        for (size_t i = 0; i < temp.size(); i++)
