How to find the stdev and mean for yolov5 model optimised using tensorrt optimizer?
Software Version
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.8.2.10409
other
Host Machine Version
other
Does incorrect parameters lead to jittery detections ? as when we implemented yolov5 with tensorrt outside driveworks the detections were smooth, we could narrow down the problem to the .json file and its parameters? Anyone know the right parameters or is there any other reason for the jitter.
  "dataConditionerParams": {
    "meanValue": [103.530, 116.280, 123.675],
    "stdev": [1.0, 1.0, 1.0],
    "splitPlanes": true,
    "pixelScaleCoefficient": -0.0039215697906911373,
    "ignoreAspectRatio": true,
    "doPerPlaneMeanNormalization": true
  "tonemapType": "none",
  "__comment": "tonemapType can be one of {none, agtm}"
We use the above parameters to currently to load the model we got it from here.
Dear @nehal,
Could you share the yolov5 preprocessing operation code(which worked with TRT alone). This helps to check parameters needed for json file in DW
This is the tensorrt pre processing script that I used I found it here.
#include "yolov5_detector_internal.hpp"
#if __has_include(<opencv2/cudaarithm.hpp>) && __has_include(<opencv2/cudawarping.hpp>)
#define YOLOV5_OPENCV_HAS_CUDA 1
#include <opencv2/cudaarithm.hpp>   /*  cv::cuda::split(...)    */
#include <opencv2/cudawarping.hpp>  /*  cv::cuda::resize(...)   */
#include <opencv2/core/cuda_stream_accessor.hpp>
#endif
#include <cuda_runtime_api.h>
namespace yolov5
namespace internal
int32_t dimsVolume(const nvinfer1::Dims& dims) noexcept
    int32_t r = 0;
    if(dims.nbDims > 0)
        r = 1;
    for(int32_t i = 0; i < dims.nbDims; ++i)
        r = r * dims.d[i];
    return r;
bool dimsToString(const nvinfer1::Dims& dims, std::string* out) noexcept
    try
        *out = "(";
            *out += std::to_string(dims.d[i]);
            if(i < dims.nbDims - 1)
                out->push_back(',');
        out->push_back(')');
    catch(const std::exception& e)
        return false;
    return true;
EngineBinding::EngineBinding() noexcept
EngineBinding::~EngineBinding() noexcept
void EngineBinding::swap(EngineBinding& other) noexcept
    std::swap(_index, other._index);
    std::swap(_name, other._name);
    std::swap(_volume, other._volume);
    nvinfer1::Dims tmp;
    std::memcpy(&tmp, &_dims, sizeof(nvinfer1::Dims));
    std::memcpy(&_dims, &other._dims, sizeof(nvinfer1::Dims));
    std::memcpy(&other._dims, &tmp, sizeof(nvinfer1::Dims));
    std::swap(_isInput, other._isInput);
const int& EngineBinding::index() const noexcept
    return _index;
const std::string& EngineBinding::name() const noexcept
    return _name;
const nvinfer1::Dims& EngineBinding::dims() const noexcept
    return _dims;
const int& EngineBinding::volume() const noexcept
    return _volume;
bool EngineBinding::isDynamic() const noexcept
    for(int i = 0; i < _dims.nbDims; ++i)
        if(_dims.d[i] == -1)
            return true;
    return false;
const bool& EngineBinding::isInput() const noexcept
    return _isInput;
void EngineBinding::toString(std::string* out) const noexcept
    std::string dimsStr;
    if(!dimsToString(_dims, &dimsStr))
        return;
    try
        *out = "name: '" + _name + "'"
                    + " ;  dims: " + dimsStr
                    + " ;  isInput: " + (_isInput ? "true" : "false")
                    + " ;  dynamic: " + (isDynamic() ? "true" : "false");
bool EngineBinding::setup(const std::unique_ptr<nvinfer1::ICudaEngine>& engine,
                    const std::string& name, EngineBinding* binding) noexcept
    try
        binding->_name = name;
        return false;
    binding->_index = engine->getBindingIndex(name.c_str());
    if(binding->_index == -1)
        return false;
    binding->_dims = engine->getBindingDimensions(binding->_index);
    binding->_volume = dimsVolume(binding->_dims);
    binding->_isInput = engine->bindingIsInput(binding->_index);
    return true;
                    const int& index, EngineBinding* binding) noexcept
    binding->_index = index;
    const char* name = engine->getBindingName(index);
    if(name == nullptr)
        return false;
    try
        binding->_name = std::string(name);
        return false;
    return true;
DeviceMemory::DeviceMemory() noexcept
DeviceMemory::~DeviceMemory() noexcept
    for(unsigned int i = 0; i < _memory.size(); ++i)
        if(_memory[i])
            cudaFree(_memory[i]);
    _memory.clear();
void DeviceMemory::swap(DeviceMemory& other) noexcept
    std::swap(_memory, other._memory);
void** DeviceMemory::begin() const noexcept
    return (void**)_memory.data();
void* DeviceMemory::at(const int& index) const noexcept
    return _memory[index];
Result DeviceMemory::setup(const std::shared_ptr<Logger>& logger,
                    DeviceMemory* output) noexcept
    const int32_t nbBindings = engine->getNbBindings();
    for(int i = 0; i < nbBindings; ++i)
        const nvinfer1::Dims dims = engine->getBindingDimensions(i);
        const int volume = dimsVolume(dims);
        try
            output->_memory.push_back(nullptr);
            logger->logf(LOGGING_ERROR, "[DeviceMemory] setup() failure: "
                        "exception: %s", e.what());
            return RESULT_FAILURE_ALLOC;
        void** ptr = &output->_memory.back();
        auto r = cudaMalloc(ptr, volume * sizeof(float));
        if(r != 0 || *ptr == nullptr)
                        "could not allocate device memory: %s",
                        cudaGetErrorString(r));
            return RESULT_FAILURE_CUDA_ERROR;
    return RESULT_SUCCESS;
bool opencvHasCuda() noexcept
    int r = 0;
    try
        r = cv::cuda::getCudaEnabledDeviceCount();
        return 0;
	return (r > 0);
PreprocessorTransform::PreprocessorTransform() noexcept
    : _inputSize(0, 0), _f(1), _leftWidth(0), _topHeight(0)
PreprocessorTransform::PreprocessorTransform(const cv::Size& inputSize,
                        const double& f, const int& leftWidth,
                        const int& topHeight) noexcept
    : _inputSize(inputSize), _f(f),
        _leftWidth(leftWidth), _topHeight(topHeight)
PreprocessorTransform::~PreprocessorTransform() noexcept
cv::Rect PreprocessorTransform::transformBbox(
                                const cv::Rect& input) const noexcept
    cv::Rect r;
    r.x = (input.x - _leftWidth) / _f;
    r.x = MAX(0, MIN(r.x, _inputSize.width-1));
    r.y = (input.y - _topHeight) / _f;
    r.y = MAX(0, MIN(r.y, _inputSize.height-1));
    r.width = input.width / _f;
    if(r.x + r.width > _inputSize.width)
        r.width = _inputSize.width - r.x;
    r.height = input.height / _f;
    if(r.y + r.height > _inputSize.height)
        r.height = _inputSize.height - r.y;
    return r;
Preprocessor::Preprocessor() noexcept
Preprocessor::~Preprocessor() noexcept
void Preprocessor::setLogger(std::shared_ptr<Logger> logger) noexcept
    _logger = logger;
bool Preprocessor::process(const int& index, const cv::Mat& input,
                        const bool& last) noexcept
    YOLOV5_UNUSED(input);
    YOLOV5_UNUSED(last);
    if(_transforms.size() < (unsigned int)index+1)
        try
            _transforms.resize(index + 1);
            _logger->logf(LOGGING_ERROR, "[Preprocessor] process() "
                            "failure: got exception setting up transforms: "
                            "%s", e.what());
            return false;
    return true;
            const cv::cuda::GpuMat& input, const bool& last) noexcept
        try
                            "%s", e.what());
            return false;
    return true;
cv::Rect Preprocessor::transformBbox(const int& index,
                    const cv::Rect& bbox) const noexcept
    return _transforms[index].transformBbox(bbox);
template <typename T>
static void setupChannels(const cv::Size& size,
                        const Preprocessor::InputType& inputType,
                        float* inputPtr,
                        std::vector<T>& channels)
    const int channelSize = size.area();
    if(inputType == Preprocessor::INPUTTYPE_BGR)  /*  INPUT_BGR   */
        /*  B channel will go here  */
        channels.push_back(T(size, CV_32FC1, inputPtr + 2 * channelSize));
        /*  G channel will go here  */
        channels.push_back(T(size, CV_32FC1, inputPtr + 1 * channelSize));
        /*  R channel will go here  */
        channels.push_back(T(size, CV_32FC1, inputPtr));
    else    /*  INPUTTYPE_RGB   */
CvCpuPreprocessor::CvCpuPreprocessor() noexcept
    : _cudaStream(nullptr), _lastType((InputType)-1), _lastBatchSize(-1),
    _networkCols(0), _networkRows(0)
CvCpuPreprocessor::~CvCpuPreprocessor() noexcept
bool CvCpuPreprocessor::setup(const nvinfer1::Dims& inputDims,
                            const int& flags, const int& batchSize,
                            float* inputMemory) noexcept
    if(!_cudaStream)
        auto r = cudaStreamCreate(&_cudaStream);
        if(r != 0)
            _logger->logf(LOGGING_ERROR, "[CvCpuPreprocessor] setup() "
                        "failure: could not create cuda stream: %s",
            return false;
    if((flags & INPUT_RGB) && (flags & INPUT_BGR))
        _logger->log(LOGGING_ERROR, "[CvCpuPreprocessor] setup() "
                    "failure: both INPUT_RGB and INPUT_BGR flags specified");
        return false;
    InputType inputType = INPUTTYPE_BGR;
    if(flags & INPUT_RGB)
        inputType = INPUTTYPE_RGB;
    if(_lastType == inputType && _lastBatchSize == batchSize)
        return true;
    _lastType = inputType;
    _lastBatchSize = batchSize;
    _networkRows = inputDims.d[2];
    _networkCols = inputDims.d[3];
    const cv::Size networkSize(_networkCols, _networkRows);
    _deviceInputMemory = inputMemory;
    _inputChannels.clear();
    try
        /*  Set up host input memory    */
        _hostInputMemory.resize(dimsVolume(inputDims));
        _inputChannels.resize(batchSize);
        for(unsigned int i = 0; i < _inputChannels.size(); ++i)
            float* inputPtr = _hostInputMemory.data()
                        + i * networkSize.area() * 3;
            std::vector<cv::Mat>& channels = _inputChannels[i];
            setupChannels<cv::Mat>(networkSize, inputType, inputPtr, channels);
        _logger->logf(LOGGING_ERROR, "[CvCpuPreprocessor] setup() failure: "
                    "got exception while trying to set up input channels: %s",
                    e.what());
        return false;
    return true;
void CvCpuPreprocessor::reset() noexcept
    /*  this will trigger setup() to take effect next time  */
    _lastType = (InputType)-1;
bool CvCpuPreprocessor::process(const int& index,
    if(!Preprocessor::process(index, input, last))
        return false;
    PreprocessorTransform& transform = _transforms[index];
    try
        if(input.rows == _networkRows && input.cols == _networkCols)
            input.convertTo(_buffer3, CV_32FC3, 1.0f / 255.0f);
            transform = PreprocessorTransform(input.size(), 1.0, 0, 0);
        else
            const double f =
                    MIN((double)_networkRows / (double)input.rows,
                        (double)_networkCols / (double)input.cols);
            const cv::Size boxSize = cv::Size(input.cols * f,
                                            input.rows * f);
            const int dr = _networkRows - boxSize.height;
            const int dc = _networkCols - boxSize.width;
            const int topHeight = std::floor(dr / 2.0);
            const int bottomHeight = std::ceil(dr / 2.0);
            const int leftWidth = std::floor(dc / 2.0);
            const int rightWidth = std::ceil(dc / 2.0);
                                            f, leftWidth, topHeight);
            cv::resize(input, _buffer1, boxSize, 0, 0, cv::INTER_LINEAR);
            cv::copyMakeBorder(_buffer1, _buffer2,
                            topHeight, bottomHeight, leftWidth, rightWidth,
                            cv::BORDER_CONSTANT, cv::Scalar(0, 0, 0));
            _buffer2.convertTo(_buffer3, CV_32FC3, 1.0f / 255.0f);
        cv::split(_buffer3, _inputChannels[index]);
        _logger->logf(LOGGING_ERROR, "[CvCpuPreprocessor] process() "
                            "failure: got exception setting up input: "
                            "%s", e.what());
        return false;
    /*  Copy from host to device    */
    if(last)
        const int volume = _inputChannels.size()    /*  batch size  */
                * 3 * _buffer3.size().area();   /*  channels * rows*cols   */
        auto r = cudaMemcpyAsync(_deviceInputMemory,
                (void*)_hostInputMemory.data(),
                (int)(volume * sizeof(float)),
                cudaMemcpyHostToDevice, _cudaStream);
        if(r != 0)
                        "failure: could not set up host-to-device transfer "
                        "for input: %s", cudaGetErrorString(r));
            return false;
    return true;
    YOLOV5_UNUSED(index);
    _logger->log(LOGGING_ERROR, "[CvCpuPreprocessor] process() failure: CUDA "
                    "method is not supported. Use CPU variant instead");
    /*  not supported   */
    return false;
cudaStream_t CvCpuPreprocessor::cudaStream() const noexcept
    return _cudaStream;
bool CvCpuPreprocessor::synchronizeCudaStream() noexcept
    auto r = cudaStreamSynchronize(_cudaStream);
    if(r != 0)
        _logger->logf(LOGGING_ERROR, "[CvCpuPreprocessor] "
                "synchronizeCudaStream() failure: %s", cudaGetErrorString(r));
        return false;
    return true;
CvCudaPreprocessor::CvCudaPreprocessor() noexcept
    : _lastType((InputType)-1), _lastBatchSize(-1),
CvCudaPreprocessor::~CvCudaPreprocessor() noexcept
bool CvCudaPreprocessor::setup(const nvinfer1::Dims& inputDims,
#ifdef YOLOV5_OPENCV_HAS_CUDA
        _logger->log(LOGGING_ERROR, "[CvCudaPreprocessor] setup() "
        return false;
        return true;
    try
            float* inputPtr = inputMemory + i * networkSize.area() * 3;
            std::vector<cv::cuda::GpuMat>& channels = _inputChannels[i];
            setupChannels<cv::cuda::GpuMat>(networkSize, inputType, inputPtr,
                                            channels);
        _logger->logf(LOGGING_ERROR, "[CvCudaPreprocessor] setup() failure: "
                    e.what());
        return false;
    return true;
#else
    YOLOV5_UNUSED(inputDims);
    YOLOV5_UNUSED(flags);
    YOLOV5_UNUSED(batchSize);
    YOLOV5_UNUSED(inputMemory);
    _logger->log(LOGGING_ERROR, "[CvCudaPreprocessor] setup() failure: "
                    "OpenCV without CUDA support");
    return false;
#endif
void CvCudaPreprocessor::reset() noexcept
bool CvCudaPreprocessor::process(const int& index,
                        const cv::Mat& input, const bool& last) noexcept
    try
        _buffer0.upload(input);
        _logger->logf(LOGGING_ERROR, "[CvCudaPreprocessor] process() "
                            "failure: got exception trying to upload input "
                            "to CUDA device: %s", e.what());
        return false;
    return process(index, _buffer0, last);
#else
    _logger->log(LOGGING_ERROR, "[CvCudaPreprocessor] process() failure: "
    return false;
#endif
        return false;
    if(index >= 1)
        /*  If we're processing a batch, first process the previous image
            before changing the internal buffers    */
        if(!synchronizeCudaStream())
            return false;
    try
            input.convertTo(_buffer3, CV_32FC3, 1.0f / 255.0f, _cudaStream);
        else
            const double f =
                                            input.rows * f);
            cv::cuda::resize(input, _buffer1, boxSize, 0, 0, cv::INTER_LINEAR,
                            _cudaStream);
            cv::cuda::copyMakeBorder(_buffer1, _buffer2,
                            cv::BORDER_CONSTANT, cv::Scalar(0, 0, 0),
                            _cudaStream);
            _buffer2.convertTo(_buffer3, CV_32FC3, 1.0f / 255.0f, _cudaStream);
        cv::cuda::split(_buffer3, _inputChannels[index], _cudaStream);
                            "%s", e.what());
        return false;
    return true;
#else
    return false;
#endif
cudaStream_t CvCudaPreprocessor::cudaStream() const noexcept
    return cv::cuda::StreamAccessor::getStream(_cudaStream);
#else
    return nullptr;
#endif
bool CvCudaPreprocessor::synchronizeCudaStream() noexcept
    try
        _cudaStream.waitForCompletion();
        _logger->logf(LOGGING_ERROR, "[CvCudaPreprocessor] "
                    "synchronizeCudaStream() failure: %s", e.what());
        return false;
    return true;
}   /*  namespace internal  */
}   /*  namespace yolov5    */
@SivaRamaKrishnaNV
Dear @nehal,
Just want to confirm if you are using DRIVE AGX Orin or DRIVE AGX Xavier platfrom? It is not clear from the description about the platform.
