How to fix error while using nvimgcodecImageCreate() function in nvImageCodec?
Now I am testing Decoder feature of nvImageCodec.
I worked on Jetson AGX Orin 64GB with Jetpack 6.0 DP and JetPack 5.1.2.
nvImageCodec is installed following this guide in the link: Guide to install nvImageCodec lib on Jetson
After installing successfully, I tried to do a test on this library by this guide: C API Samples
For single image decode, I met an error in the Step 5, at this code line:
nvimgcodecImageCreate(instance, &image, &input_image_info);
This function calling returns a status of NVIMGCODEC_STATUS_INVALID_PARAMETER.
So I want to require any help for this issue from anyone.
Thanks in advance.
You may get better help by asking on the Jetson AGX Orin forum.
Thanks Robert. I will do that.
I tested also on Ubuntu 22.04 (x86_64 system) with CUDA 12.2 and faced the same problem.
