How to Fix Mouse Click Single Object Selection in YOLOv8 + DeepStream + DeepSORT?
System & Environment:
  • Device: Jetson Xavier NX
  • JetPack: 5.1.4
  • DeepStream SDK: 6.3
  • GStreamer: 1.16.3
  • gst-launch-1.0: 1.16.3
  • CUDA: 11.4
  • YOLOv8 Model: TensorRT engine loaded
  • DeepSORT: Using deep_sort_realtime Python package
Issue:
I implemented an object detection and tracking pipeline using YOLOv8 + DeepStream + DeepSORT with OpenCV for display. I want to select a single object using mouse click, but the selection does not work properly. Clicking on the object does not consistently select the nearest object.
I would like guidance on proper setup or modifications to enable reliable mouse-based object selection.
1.DeepStream supports deepsort tracing; please refer to Gst-nvtracker — DeepStream documentation and /opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_tracker_NvDeepSORT.yml
Using third-party libraries is not the optimal solution.
2.OpenCV is probably completely unnecessary. The following pipeline can be constructed.
nvinfer (yolov8) --> tracker (with deepsort config) --> nvdsosd (draw bbox) --> nv3dsink
Returning to the problem itself, A feasible solution is:
  1. Record the mouse click area, then calculate which object’s bounding box that area corresponds to.
  2. After finding the corresponding object, record the object ID provided by the tracker.
  3. When drawing the bounding box, only draw those matching the object ID.
Sorry for the delay in getting back to you and thank you for your replay.
Could you simplify the provided solutions?
can I use Deepstream with?
Please debug and modify it yourself. This feature does not depend on any deepstream functionality.
This sample is based on deepstream_test_2.py. Clicking on the corresponding object will make the bounding box thicker.
#!/usr/bin/env python3
# SPDX-FileCopyrightText: Copyright (c) 2019-2023 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# SPDX-License-Identifier: Apache-2.0
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
import sys
sys.path.append("../")
import platform
import configparser
import gi
gi.require_version("Gst", "1.0")
gi.require_version("Gtk", "3.0")
gi.require_version("GdkX11", "3.0")
gi.require_version("GstVideo", "1.0")
from gi.repository import GLib, Gst, Gtk, Gdk, GdkX11, GstVideo
from common.platform_info import PlatformInfo
from common.bus_call import bus_call
import pyds
PGIE_CLASS_ID_VEHICLE = 0
PGIE_CLASS_ID_BICYCLE = 1
PGIE_CLASS_ID_PERSON = 2
PGIE_CLASS_ID_ROADSIGN = 3
MUXER_BATCH_TIMEOUT_USEC = 33000
# Global statistics tracking
global_stats = {
    "frame_count": 0,
    "vehicle_count": 0,
    "person_count": 0,
    "bicycle_count": 0,
    "roadsign_count": 0,
    "total_objects": 0,
# Global variables for bbox selection
current_bboxes = []  # Store current frame bboxes
selected_object_id = None  # ID of selected object
video_scale = 1.0  # Video scaling factor
video_offset_x = 0.0  # Video X offset in widget
video_offset_y = 0.0  # Video Y offset in widget
video_display_width = 0.0  # Actual video display width in widget
video_display_height = 0.0  # Actual video display height in widget
class DeepStreamGUI:
    def __init__(self, pipeline=None):
        self.pipeline = pipeline
        self.is_playing = False
        # Create the main window
        self.window = Gtk.Window()
        self.window.set_title("DeepStream Test2 - Auto-Play GUI")
        self.window.set_default_size(1200, 800)
        self.window.connect("delete-event", self.on_window_delete)
        # Create main layout
        main_box = Gtk.VBox(spacing=10)
        self.window.add(main_box)
        # Create control panel
        control_frame = Gtk.Frame(label="Control Panel")
        control_box = Gtk.HBox(spacing=10)
        control_frame.add(control_box)
        # File chooser button
        self.file_button = Gtk.Button(label="Select File")
        self.file_button.connect("clicked", self.on_file_choose_clicked)
        control_box.pack_start(self.file_button, False, False, 0)
        # Clear selection button
        self.clear_button = Gtk.Button(label="Clear Selection")
        self.clear_button.connect("clicked", self.on_clear_selection_clicked)
        control_box.pack_start(self.clear_button, False, False, 0)
        main_box.pack_start(control_frame, False, False, 0)
        # Create video area
        video_frame = Gtk.Frame(label="Video Display")
        self.video_area = Gtk.DrawingArea()
        self.video_area.set_size_request(640, 480)
        self.video_area.set_double_buffered(
            False
        )  # Important: disable double buffering for video overlay
        # Enable mouse events for bbox selection
        self.video_area.set_events(Gdk.EventMask.BUTTON_PRESS_MASK)
        self.video_area.connect("button-press-event", self.on_video_click)
        video_frame.add(self.video_area)
        main_box.pack_start(video_frame, True, True, 0)
        # Create statistics panel
        stats_frame = Gtk.Frame(label="Statistics")
        stats_box = Gtk.VBox(spacing=5)
        stats_frame.add(stats_box)
        # Statistics labels
        self.frame_label = Gtk.Label(label="Frames: 0")
        self.vehicle_label = Gtk.Label(label="Vehicles: 0")
        self.person_label = Gtk.Label(label="Persons: 0")
        self.bicycle_label = Gtk.Label(label="Bicycles: 0")
        self.roadsign_label = Gtk.Label(label="Road Signs: 0")
        self.total_label = Gtk.Label(label="Total Objects: 0")
        # Add separator
        separator = Gtk.Separator(orientation=Gtk.Orientation.HORIZONTAL)
        # Selected object info
        self.selected_label = Gtk.Label(label="Selected: None")
        self.selected_label.set_markup("<b>Selected: None</b>")
        stats_box.pack_start(self.frame_label, False, False, 0)
        stats_box.pack_start(self.vehicle_label, False, False, 0)
        stats_box.pack_start(self.person_label, False, False, 0)
        stats_box.pack_start(self.bicycle_label, False, False, 0)
        stats_box.pack_start(self.roadsign_label, False, False, 0)
        stats_box.pack_start(self.total_label, False, False, 0)
        stats_box.pack_start(separator, False, False, 5)
        stats_box.pack_start(self.selected_label, False, False, 0)
        main_box.pack_start(stats_frame, False, False, 0)
        # Update timer
        GLib.timeout_add(100, self.update_stats)
        self.selected_file = None
    def on_window_delete(self, widget, event):
        if self.pipeline:
            self.pipeline.set_state(Gst.State.NULL)
        Gtk.main_quit()
        return False
    def on_file_choose_clicked(self, button):
        dialog = Gtk.FileChooserDialog(
            title="Select Video File",
            parent=self.window,
            action=Gtk.FileChooserAction.OPEN,
        dialog.add_buttons(
            Gtk.STOCK_CANCEL,
            Gtk.ResponseType.CANCEL,
            Gtk.STOCK_OPEN,
            Gtk.ResponseType.OK,
        # Add file filters
        filter_video = Gtk.FileFilter()
        filter_video.set_name("Video Files")
        filter_video.add_mime_type("video/*")
        filter_video.add_pattern("*.h264")
        dialog.add_filter(filter_video)
        response = dialog.run()
        if response == Gtk.ResponseType.OK:
            self.selected_file = dialog.get_filename()
            print(f"Selected file: {self.selected_file}")
        dialog.destroy()
    def update_stats(self):
        global selected_object_id, current_bboxes
        self.frame_label.set_text(f"Frames: {global_stats['frame_count']}")
        self.vehicle_label.set_text(f"Vehicles: {global_stats['vehicle_count']}")
        self.person_label.set_text(f"Persons: {global_stats['person_count']}")
        self.bicycle_label.set_text(f"Bicycles: {global_stats['bicycle_count']}")
        self.roadsign_label.set_text(f"Road Signs: {global_stats['roadsign_count']}")
        self.total_label.set_text(f"Total Objects: {global_stats['total_objects']}")
        # Update selected object info
        if selected_object_id is not None:
            # Find the selected object in current bboxes
            selected_info = None
            for bbox_info in current_bboxes:
                left, top, width, height, obj_id, class_id = bbox_info
                if obj_id == selected_object_id:
                    selected_info = bbox_info
                    break
            if selected_info:
                left, top, width, height, obj_id, class_id = selected_info
                class_names = {
                    PGIE_CLASS_ID_VEHICLE: "Vehicle",
                    PGIE_CLASS_ID_PERSON: "Person",
                    PGIE_CLASS_ID_BICYCLE: "Bicycle",
                    PGIE_CLASS_ID_ROADSIGN: "Road Sign",
                class_name = class_names.get(class_id, "Unknown")
                    f"<b>Selected: {class_name} (ID: {obj_id})</b>"
            else:
                self.selected_label.set_markup("<b>Selected: None (object lost)</b>")
        else:
        return True
    def on_video_click(self, widget, event):
        """Handle mouse click on video area for bbox selection"""
        global selected_object_id, current_bboxes, video_scale, video_offset_x, video_offset_y
        # Get click coordinates in widget
        click_x = event.x
        click_y = event.y
        # Check if click is within the actual video display area
        if (
            click_x < video_offset_x
            or click_x > video_offset_x + video_display_width
            or click_y < video_offset_y
            or click_y > video_offset_y + video_display_height
            print(f"Click outside video area: ({click_x:.1f}, {click_y:.1f})")
            return True
        # Convert widget coordinates to video original coordinates (1920x1080)
        # Step 1: Remove offset to get coordinates relative to video display area
        video_display_x = click_x - video_offset_x
        video_display_y = click_y - video_offset_y
        # Step 2: Convert from video display area to original video coordinates
        # video_display_width = 1920 * video_scale
        # So: video_original_x = video_display_x * 1920 / video_display_width
        #     video_original_x = video_display_x / video_scale
        video_original_x = (
            (video_display_x * 1920.0) / video_display_width
            if video_display_width > 0
            else 0
        video_original_y = (
            (video_display_y * 1080.0) / video_display_height
            if video_display_height > 0
            else 0
        print(f"Click at widget: ({click_x:.1f}, {click_y:.1f})")
        print(f"Video display: ({video_display_x:.1f}, {video_display_y:.1f})")
        print(
            f"Video original (1920x1080): ({video_original_x:.1f}, {video_original_y:.1f})"
        print(
            f"Video area: offset=({video_offset_x:.1f}, {video_offset_y:.1f}), size=({video_display_width:.1f}x{video_display_height:.1f}), scale={video_scale:.3f}"
        # Find bbox that contains the click point (bbox coordinates are in original video space)
            right = left + width
            bottom = top + height
            if left <= video_original_x <= right and top <= video_original_y <= bottom:
                selected_object_id = obj_id
                print(f"Selected object ID: {obj_id}, class: {class_id}")
                print(
                    f"Object bbox (original coords): ({left:.1f}, {top:.1f}, {width:.1f}x{height:.1f})"
                break
        if selected_object_id is None:
            print("No object selected, showing all bboxes")
        return True
    def on_clear_selection_clicked(self, button):
        """Clear the selected object and show all bboxes"""
        print("Selection cleared, showing all objects")
    def show(self):
        self.window.show_all()
    def get_video_widget(self):
        return self.video_area
    def get_window_handle(self):
        """Get video_area window handle for GstVideoOverlay"""
        # Ensure window is realized
        if self.video_area.get_window():
            return self.video_area.get_window().get_xid()
        return None
def osd_sink_pad_buffer_probe(pad, info, u_data):
    global global_stats, current_bboxes, selected_object_id
    frame_number = 0
    # Intiallizing object counter with 0.
    obj_counter = {
        PGIE_CLASS_ID_VEHICLE: 0,
        PGIE_CLASS_ID_PERSON: 0,
        PGIE_CLASS_ID_BICYCLE: 0,
        PGIE_CLASS_ID_ROADSIGN: 0,
    num_rects = 0
    # Clear current bboxes for this frame
    current_bboxes = []
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        print("Unable to get GstBuffer ")
        return
    # Retrieve batch metadata from the gst_buffer
    # Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
    # C address of gst_buffer as input, which is obtained with hash(gst_buffer)
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        try:
            # Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
            # The casting is done by pyds.NvDsFrameMeta.cast()
            # The casting also keeps ownership of the underlying memory
            # in the C code, so the Python garbage collector will leave
            # it alone.
        except StopIteration:
            break
        frame_number = frame_meta.frame_num
        num_rects = frame_meta.num_obj_meta
        l_obj = frame_meta.obj_meta_list
        while l_obj is not None:
            try:
                # Casting l_obj.data to pyds.NvDsObjectMeta
                obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
                break
            obj_counter[obj_meta.class_id] += 1
            # Store bbox information for click detection
            bbox_info = (
                obj_meta.rect_params.left,
                obj_meta.rect_params.top,
                obj_meta.rect_params.width,
                obj_meta.rect_params.height,
                obj_meta.object_id,
                obj_meta.class_id,
            current_bboxes.append(bbox_info)
            # Control bbox visibility based on selection
                if obj_meta.object_id == selected_object_id:
                    # Show selected object with highlighted color and thick border
                    obj_meta.rect_params.border_color.set(1.0, 0.0, 0.0, 1.0)  # Red
                    obj_meta.rect_params.border_width = 6
                    obj_meta.text_params.font_params.font_color.set(
                        1.0, 0.0, 0.0, 1.0
                    )  # Red text
                else:
                    # Show other objects with normal colors but thinner border
                    if obj_meta.class_id == PGIE_CLASS_ID_PERSON:
                            0.0, 1.0, 0.0, 1.0
                        )  # Green
                    elif obj_meta.class_id == PGIE_CLASS_ID_VEHICLE:
                            0.0, 0.0, 1.0, 1.0
                        )  # Blue
                    elif obj_meta.class_id == PGIE_CLASS_ID_BICYCLE:
                            1.0, 1.0, 0.0, 1.0
                        )  # Yellow
                    elif obj_meta.class_id == PGIE_CLASS_ID_ROADSIGN:
                            1.0, 0.0, 1.0, 1.0
                        )  # Magenta
                    obj_meta.rect_params.border_width = (
                        1  # Thinner border for non-selected objects
            else:
                # Show all objects with default colors and normal border width
                    obj_meta.rect_params.border_color.set(0.0, 1.0, 0.0, 1.0)  # Green
                    obj_meta.rect_params.border_color.set(0.0, 0.0, 1.0, 1.0)  # Blue
                    obj_meta.rect_params.border_color.set(1.0, 1.0, 0.0, 1.0)  # Yellow
                    obj_meta.rect_params.border_color.set(1.0, 0.0, 1.0, 1.0)  # Magenta
                obj_meta.rect_params.border_width = 2
            try:
                l_obj = l_obj.next
                break
        # Acquiring a display meta object. The memory ownership remains in
        # the C code so downstream plugins can still access it. Otherwise
        # the garbage collector will claim it when this probe function exits.
        display_meta = pyds.nvds_acquire_display_meta_from_pool(batch_meta)
        display_meta.num_labels = 1
        py_nvosd_text_params = display_meta.text_params[0]
        # Setting display text to be shown on screen
        # Note that the pyds module allocates a buffer for the string, and the
        # memory will not be claimed by the garbage collector.
        # Reading the display_text field here will return the C address of the
        # allocated string. Use pyds.get_string() to get the string content.
        py_nvosd_text_params.display_text = "Frame Number={} Number of Objects={} Vehicle_count={} Person_count={}".format(
            frame_number,
            num_rects,
            obj_counter[PGIE_CLASS_ID_VEHICLE],
            obj_counter[PGIE_CLASS_ID_PERSON],
        # Now set the offsets where the string should appear
        py_nvosd_text_params.x_offset = 10
        py_nvosd_text_params.y_offset = 12
        # Font , font-color and font-size
        py_nvosd_text_params.font_params.font_name = "Serif"
        py_nvosd_text_params.font_params.font_size = 10
        # set(red, green, blue, alpha); set to White
        py_nvosd_text_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
        # Text background color
        py_nvosd_text_params.set_bg_clr = 1
        # set(red, green, blue, alpha); set to Black
        py_nvosd_text_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
        # Using pyds.get_string() to get display_text as string
        print(pyds.get_string(py_nvosd_text_params.display_text))
        pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
        try:
            l_frame = l_frame.next
            break
    # past tracking meta data
    l_user = batch_meta.batch_user_meta_list
    while l_user is not None:
        try:
            # Note that l_user.data needs a cast to pyds.NvDsUserMeta
            # The casting is done by pyds.NvDsUserMeta.cast()
            # it alone
            user_meta = pyds.NvDsUserMeta.cast(l_user.data)
            break
        if (
            user_meta
            and user_meta.base_meta.meta_type
            == pyds.NvDsMetaType.NVDS_TRACKER_PAST_FRAME_META
            try:
                # Note that user_meta.user_meta_data needs a cast to pyds.NvDsTargetMiscDataBatch
                # The casting is done by pyds.NvDsTargetMiscDataBatch.cast()
                # it alone
                pPastDataBatch = pyds.NvDsTargetMiscDataBatch.cast(
                break
            for miscDataStream in pyds.NvDsTargetMiscDataBatch.list(pPastDataBatch):
                print("streamId=", miscDataStream.streamID)
                print("surfaceStreamID=", miscDataStream.surfaceStreamID)
                for miscDataObj in pyds.NvDsTargetMiscDataStream.list(miscDataStream):
                    print("numobj=", miscDataObj.numObj)
                    print("uniqueId=", miscDataObj.uniqueId)
                    print("classId=", miscDataObj.classId)
                    print("objLabel=", miscDataObj.objLabel)
                    for miscDataFrame in pyds.NvDsTargetMiscDataObject.list(
                        miscDataObj
                        print("frameNum:", miscDataFrame.frameNum)
                        print("tBbox.left:", miscDataFrame.tBbox.left)
                        print("tBbox.width:", miscDataFrame.tBbox.width)
                        print("tBbox.top:", miscDataFrame.tBbox.top)
                        print("tBbox.right:", miscDataFrame.tBbox.height)
                        print("confidence:", miscDataFrame.confidence)
                        print("age:", miscDataFrame.age)
        try:
            l_user = l_user.next
            break
    # Update global statistics
    global_stats["frame_count"] = frame_number
    global_stats["vehicle_count"] = obj_counter[PGIE_CLASS_ID_VEHICLE]
    global_stats["person_count"] = obj_counter[PGIE_CLASS_ID_PERSON]
    global_stats["bicycle_count"] = obj_counter[PGIE_CLASS_ID_BICYCLE]
    global_stats["roadsign_count"] = obj_counter[PGIE_CLASS_ID_ROADSIGN]
    global_stats["total_objects"] = num_rects
    return Gst.PadProbeReturn.OK
def custom_bus_call(bus, message, loop, gui, sink):
    Custom bus callback function for handling GstVideoOverlay window setup
    t = message.type
    if t == Gst.MessageType.EOS:
        print("End-of-stream\n")
        loop.quit()
    elif t == Gst.MessageType.WARNING:
        err, debug = message.parse_warning()
        print("Warning: %s: %s\n" % (err, debug))
    elif t == Gst.MessageType.ERROR:
        err, debug = message.parse_error()
        print("Error: %s: %s\n" % (err, debug))
        loop.quit()
    elif t == Gst.MessageType.ELEMENT:
        # Handle GstVideoOverlay prepare-window-handle message
        if message.get_structure().get_name() == "prepare-window-handle":
            print("Setting window handle for video overlay...")
            # Wait a bit to ensure window is realized
            GLib.timeout_add(100, set_window_handle, gui, sink)
    return True
def set_window_handle(gui, sink):
    """Set window handle for video overlay"""
    window_handle = gui.get_window_handle()
    if window_handle:
        print(f"Setting window handle: {window_handle}")
        sink.set_window_handle(window_handle)
        return False  # Execute only once
    else:
        print("Window handle not ready, retrying...")
        return True  # Continue retrying
def on_sync_message(bus, message, gui, sink):
    """Handle sync messages, especially prepare-window-handle"""
    if message.get_structure() is None:
        return
    message_name = message.get_structure().get_name()
    if message_name == "prepare-window-handle":
        print("Received prepare-window-handle, setting up video overlay...")
        # Delay setting window handle to ensure GTK window is fully realized
        GLib.timeout_add(200, set_window_handle, gui, sink)
def main():
    # Initialize GUI for file selection
    Gtk.init(None)
    gui = DeepStreamGUI()
    gui.show()
    dialog = Gtk.MessageDialog(
        parent=gui.window,
        flags=0,
        message_type=Gtk.MessageType.INFO,
        buttons=Gtk.ButtonsType.OK,
        text="Please use the GUI to select a video file",
    dialog.run()
    dialog.destroy()
    # Wait for file selection or quit
    while not gui.selected_file:
        Gtk.main_iteration_do(False)
        if not gui.window.get_visible():
            sys.exit(1)
    input_file = gui.selected_file
    platform_info = PlatformInfo()
    # Standard GStreamer initialization
    Gst.init(None)
    # Create gstreamer elements
    # Create Pipeline element that will form a connection of other elements
    print("Creating Pipeline \n ")
    pipeline = Gst.Pipeline()
    if not pipeline:
        sys.stderr.write(" Unable to create Pipeline \n")
    # Source element for reading from the file
    print("Creating Source \n ")
    source = Gst.ElementFactory.make("filesrc", "file-source")
    if not source:
        sys.stderr.write(" Unable to create Source \n")
    # Since the data format in the input file is elementary h264 stream,
    # we need a h264parser
    print("Creating H264Parser \n")
    h264parser = Gst.ElementFactory.make("h264parse", "h264-parser")
    if not h264parser:
        sys.stderr.write(" Unable to create h264 parser \n")
    # Use nvdec_h264 for hardware accelerated decode on GPU
    print("Creating Decoder \n")
    decoder = Gst.ElementFactory.make("nvv4l2decoder", "nvv4l2-decoder")
    if not decoder:
        sys.stderr.write(" Unable to create Nvv4l2 Decoder \n")
    # Create nvstreammux instance to form batches from one or more sources.
    streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
    if not streammux:
        sys.stderr.write(" Unable to create NvStreamMux \n")
    # Use nvinfer to run inferencing on decoder's output,
    # behaviour of inferencing is set through config file
    pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
    if not pgie:
        sys.stderr.write(" Unable to create pgie \n")
    tracker = Gst.ElementFactory.make("nvtracker", "tracker")
    if not tracker:
        sys.stderr.write(" Unable to create tracker \n")
    sgie1 = Gst.ElementFactory.make("nvinfer", "secondary1-nvinference-engine")
    if not sgie1:
        sys.stderr.write(" Unable to make sgie1 \n")
    sgie2 = Gst.ElementFactory.make("nvinfer", "secondary2-nvinference-engine")
    if not sgie2:
        sys.stderr.write(" Unable to make sgie2 \n")
    nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
    if not nvvidconv:
        sys.stderr.write(" Unable to create nvvidconv \n")
    # Create OSD to draw on the converted RGBA buffer
    nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
    if not nvosd:
        sys.stderr.write(" Unable to create nvosd \n")
    # Create video sink using GstVideoOverlay for better compatibility
    print("Creating video sink with GstVideoOverlay \n")
    sink = None
    if platform_info.is_integrated_gpu():
        print("Using nv3dsink for integrated GPU \n")
        sink = Gst.ElementFactory.make("nv3dsink", "nv3d-sink")
        if not sink:
            sys.stderr.write(" Unable to create nv3dsink \n")
    else:
        if platform_info.is_platform_aarch64():
            print("Using nv3dsink for aarch64 platform \n")
        else:
            print("Using nveglglessink for x86 platform \n")
            sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
            if not sink:
                print("nveglglessink not available, trying nv3dsink \n")
    if not sink:
        sys.stderr.write(" Unable to create any video sink \n")
        return -1
    if not isinstance(sink, GstVideo.VideoOverlay):
        print("Warning: Sink does not support VideoOverlay interface")
    else:
        print("Sink supports VideoOverlay interface")
    print("Playing file %s " % input_file)
    source.set_property("location", input_file)
    # Set GUI pipeline reference
    gui.pipeline = pipeline
    streammux.set_property("width", 1920)
    streammux.set_property("height", 1080)
    streammux.set_property("batch-size", 1)
    streammux.set_property("batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC)
    # Set properties of pgie and sgie
    pgie.set_property("config-file-path", "dstest2_pgie_config.txt")
    sgie1.set_property("config-file-path", "dstest2_sgie1_config.txt")
    sgie2.set_property("config-file-path", "dstest2_sgie2_config.txt")
    # Set properties of tracker
    config = configparser.ConfigParser()
    config.read("dstest2_tracker_config.txt")
    config.sections()
    for key in config["tracker"]:
        if key == "tracker-width":
            tracker_width = config.getint("tracker", key)
            tracker.set_property("tracker-width", tracker_width)
        if key == "tracker-height":
            tracker_height = config.getint("tracker", key)
            tracker.set_property("tracker-height", tracker_height)
        if key == "gpu-id":
            tracker_gpu_id = config.getint("tracker", key)
            tracker.set_property("gpu_id", tracker_gpu_id)
        if key == "ll-lib-file":
            tracker_ll_lib_file = config.get("tracker", key)
            tracker.set_property("ll-lib-file", tracker_ll_lib_file)
        if key == "ll-config-file":
            tracker_ll_config_file = config.get("tracker", key)
            tracker.set_property("ll-config-file", tracker_ll_config_file)
    print("Adding elements to Pipeline \n")
    pipeline.add(source)
    pipeline.add(h264parser)
    pipeline.add(decoder)
    pipeline.add(streammux)
    pipeline.add(pgie)
    pipeline.add(tracker)
    pipeline.add(sgie1)
    pipeline.add(sgie2)
    pipeline.add(nvvidconv)
    pipeline.add(nvosd)
    pipeline.add(sink)
    # we link the elements together
    # file-source -> h264-parser -> nvh264-decoder ->
    # nvinfer -> nvvidconv -> nvosd -> videoconvert -> video-renderer
    print("Linking elements in the Pipeline \n")
    source.link(h264parser)
    h264parser.link(decoder)
    sinkpad = streammux.request_pad_simple("sink_0")
    if not sinkpad:
        sys.stderr.write(" Unable to get the sink pad of streammux \n")
    srcpad = decoder.get_static_pad("src")
    if not srcpad:
        sys.stderr.write(" Unable to get source pad of decoder \n")
    srcpad.link(sinkpad)
    streammux.link(pgie)
    pgie.link(tracker)
    tracker.link(sgie1)
    sgie1.link(sgie2)
    sgie2.link(nvvidconv)
    nvvidconv.link(nvosd)
    nvosd.link(sink)
    # create and event loop and feed gstreamer bus mesages to it
    loop = GLib.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect("message", custom_bus_call, loop, gui, sink)
    bus.enable_sync_message_emission()
    bus.connect("sync-message::element", on_sync_message, gui, sink)
    # Lets add probe to get informed of the meta data generated, we add probe to
    # the sink pad of the osd element, since by that time, the buffer would have
    # had got all the metadata.
    osdsinkpad = nvosd.get_static_pad("sink")
    if not osdsinkpad:
        sys.stderr.write(" Unable to get sink pad of nvosd \n")
    osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)
    # Show GUI
    gui.show()
    # Calculate video to widget scaling factors and positioning
    def update_scaling_factors():
        global video_scale, video_offset_x, video_offset_y, video_display_width, video_display_height
        widget_width = gui.video_area.get_allocated_width()
        widget_height = gui.video_area.get_allocated_height()
        # Video dimensions are 1920x1080 (set in streammux)
        video_width = 1920.0
        video_height = 1080.0
        if widget_width > 0 and widget_height > 0:
            # Calculate scaling to fit video in widget while maintaining aspect ratio
            scale_x = widget_width / video_width
            scale_y = widget_height / video_height
            video_scale = min(
                scale_x, scale_y
            )  # Use uniform scaling to maintain aspect ratio
            # Calculate actual video display size after scaling
            video_display_width = video_width * video_scale
            video_display_height = video_height * video_scale
            # Calculate offset to center the video in the widget
            video_offset_x = (widget_width - video_display_width) / 2.0
            video_offset_y = (widget_height - video_display_height) / 2.0
            print(f"Widget: {widget_width}x{widget_height}")
            print(
                f"Video display: {video_display_width:.1f}x{video_display_height:.1f}"
            print(f"Offset: ({video_offset_x:.1f}, {video_offset_y:.1f})")
            print(f"Scale: {video_scale:.3f}")
        return True  # Continue calling this function
    # Update scaling factors periodically
    GLib.timeout_add(1000, update_scaling_factors)
    # Ensure GTK window is fully realized before starting pipeline
    def start_pipeline():
        print("Starting pipeline - Auto-play enabled \n")
        # start play back and play to completion
        pipeline.set_state(Gst.State.PLAYING)
        print("Video will play automatically to completion")
    # Delay pipeline start to ensure window is realized
    GLib.timeout_add(500, start_pipeline)
    try:
        # Use GTK main loop instead of GLib.MainLoop
        Gtk.main()
    except:
        pass
    # cleanup
if __name__ == "__main__":
    sys.exit(main())
Thank you. I will check it :)
**I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks**
