Dear community,
Please help me
My setup:
Auvidea J120
Jetson TX1
Auvidea Toshiba adapter
Toshiba camera module 41,3 Mp
Auvidea support send me “manual”
"1. Flash system with JetPack 3.0 + cuda
Copy kernel_24.2.1_galileo_all_included_bin_vx.x.x.tar.gz to TX1 module
Extract files
tar -zxvf kernel_24.2.1_galileo_all_included_bin_vx.x.x.tar.gz -
Go into the extracted file
cd kernel_24.2.1_galileo_all_included -
Copy boot, modules file to system boot:
sudo cp -rf /boot/* /boot/.
sudo cp -rf /boot/dtb/* /boot/.
sudo cp -rf /modules/lib/* /lib/.
// -rf forces an overwrite of an existing file, and copies directories recursively -
sudo reboot
Make sure that Galileo2 stands in /etc/modules over nvhost_vi
sudo gedit /etc/modules
7.1 enter galileo2 over nvhost_vi save file and close it -
Load galileo 2 and initialize it:
sudo modprobe galileo2 // if this does not work make sure that galileo2.ko is in /lib/modules/3.10.96-tegra/kernel/drivers/media/i2c/.
sudo depmod //this will make sure that galileo2 is automatically loaded on start up -
Reboot to apply changes and you should see now in the devices file 6 video devices:
ls -s /dev/video*
video0, video1, video2, video3, video4, video5
// on J120 the camera module should be recognized as video0 or video4, but all six devices should show up
You can now execute the following gstreamer command to get the video of the inputs:
1080p60: gst-launch-1.0 v4l2src device=/dev/video0 ! ‘video/x-raw, width=1920, height=1080, framerate=60/1, format=UYVY’ ! nvvidconv ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, framerate=60/1, format=I420’ ! nvoverlaysink sync=false "
Ok,
I flashed module from Jetpack 3.0 BSP firmware Auvidea 2.1
After that I tried to copy files
I discovered that in my modules I have 3.10.96+ and 3.10.96-tegra, system boot 3.10.96+
modprobe not found galileo2 in 3.10.96+
I tried copy galileo2.ko to 3.10.96+
ls -s /dev/video*
0 /dev/video4
gst-launch, nvgstcapture not results…
