I have 2 jetsons with secure boot enabled but they have different KEK2 keys so how can I reflash the backup of jetson 1 to jetson 2 and vice versa?
Jetpack 5.1.4 - Jetson Xavier NX - EMMC
hello user34150,
you need to generate individual backup image per device as long as you used different keys.
If I have a Jetson Xavier NX without secure boot, and then I create a backup and reflash it on a Jetson with secure boot, replacing eks.img
, will it work?
hello user34150,
please refer to Tool for EKB Generation.
you should run the EKB generation tool to generate EKS image separately.
How to flash with ekb do you have any specific instructions for the case of jetson xavier NX emmx?
hello user34150,
you must perform a full flash since partition update has disabled on fused device.
otherwise, you may running with flash script to update eks
partition. (eks_t194.img)
for instance, $ sudo ./flash.sh -k eks jetson-xavier-nx-devkit-emmc mmcblk0p1
