I’m trying to build the Drive 10 AGX kernel provided in the sdk with some extra kernel modules and then flash it to the my Drive AGX Xavior. I’ve followed these two guides for building a flashing kernel and then for using bootburn:
https://docs.nvidia.com/drive/drive_os_5.1.6.1L/nvvib_docs/index.html#page/DRIVE_OS_Linux_SDK_Development_Guide/Flashing%20Customization/flashing_kernel.html
The bootburn command I use is including A_1_kernel A_1_kernel-dtb and A_1_ramdisk. The result of the bootburn command is from what I can tell successful, and if I log in to a serial terminal after the flashing I can see that it indeed has loaded my newly built dts. But when I run a tegrarecovery x1 off and then tegrareset x1 to get the tegra up and running again it still uses the old dts when booting.
What am I missing? Is there some other guide I should follow?
Best regards
Mårten
