How to flash only kernel image to Xavier ?
Dear sir,
I tried copy compiled Image to /boot/ after Xavier bootup and using command to flash Xavier, both failed.
sudo ./flash.sh -r -k kernel jetson-xavier mmcblk0p1
Can u give some suggestion on this?
Thanks so much.
dennis,
You need to put it under Linux_for_Tegra/kernel on host.
Dear WayneWWW,
I tried three methods:
  1. After Xavier bootup, copy Image to /boot/ dircetory, failed (this works okay on TX2)
  2. Copy Image to Linux_for_Tegra/kernel/ directory, and running command, but still failed when bootup looking dmesg log :
Linux version 4.9.108-tegra (buildbrain@mobile-u64-2565) (gcc version 6.4.1 20170707 (Linaro GCC 6.4-2017.08) ) #1 SMP PREEMPT Wed Oct 31 15:17:21 PDT 2018
  1. Copy Image to Linux_for_Tegra/kernel/ directory, and running flash all image command, but still failed when bootup looking dmesg log :
sudo ./flash.sh jetson-xavier mmcblk0p1
Dear WayneWWW,
I made a mistake, using method2, Xavier kernel image works, thanks so much.
FYI, newer releases of the TX2 will also fail with a simple file copy of Image into “/boot”.
I tried this cmd on Jetpack 4.4, but failed.It seems that the flashing process complete,but indeed the kernel is still the previous one.
Could you kindly help me?
Thank you very much!
It has been changed. Xavier supports to update kernel by putting new Image to /boot/Image now.
