How to flash only QSPI on Jetson Orin Nano in JetPack5.1.1/L4T 35.3.1
I would like to know whether we can flash only QSPI on Jetson Orin Nano in JetPack5.1.1/L4T 35.3.1 or not.
You answered that “you could not only flash QSPI of Orin NX” below.
However, there is a guide to flash only QSPI on Jetson Orin series in the following.
$ sudo ./flash.sh --no-systemimg -c bootloader/t186ref/cfg/flash_t234_qspi.xml <board> <rootdev>
https://docs.nvidia.com/jetson/archives/r35.3.1/DeveloperGuide/text/SD/FlashingSupport.html
Could you please tell us if we can flash only QSPI on Jetson Orin Nano in JetPack5.1.1/L4T 35.3.1?
HW : Jetson Orin Nano SOM + custom carrierboard + SSD
SW : JetPack5.1.1/L4T 35.3.1
thanks
cd Linux_for_Tegra; sudo ADDITIONAL_DTB_OVERLAY_OPT="BootOrderNvme.dtbo" ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" --network usb0 jetson-orin-nano-devkit external
flash QSPI with external device nvme.
Hi A_Y,
Yes, you could use the following command to flash QSPI only for Orin Nano.
sudo ./flash.sh -c bootloader/t186ref/cfg/flash_t234_qspi.xml --no-systemimg <board> nvme0n1p1
To KevinFFF-san,
Thank you for the answer. It is clear for us.
thanks
