Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
I have already flashed Jetson Xavier AGX Jetpack 5.0.2 (rev 1) on my target h/w (Jetson AGX Xavier Platform). Now i’m writing the Camera i2c driver for AR0820. After compilation of Camera Driver using cmd:
make ARCH=arm64 O=$KERNEL_OUT CROSS_COMPILE=$CROSS_COMPILE -j4
and Installing the modules to the output directory using command:
make modules_install ARCH=arm64 O=$KERNEL_OUT CROSS_COMPILE=$CROSS_COMPILE INSTALL_MOD_PATH=$KERNEL_MODULES_OUT
i then performed cmd: sudo ./apply_binaries.sh
But now i want to flash only my updates and do not want to reflash again from the scratch using cmd: sudo ./flash.sh jetson-agx-xavier-devkit mmcblk0p1
Please let me know how i can only flash everytime the updates (drivers) that i build in my Ubuntu system.
please use -k options to have partition update, you may see-also Flashing a Specific Partition for reference,
for example, $ sudo ./flash.sh -r -k kernel jetson-agx-xavier-devkit mmcblk0p1
by the way,
it’s supported reading kernel image via file system, once you’ve define LINUX entry in the extlinux.conf, you may update kernel image without re-flash the target.
please refer to CBoot session, and please check [Kernel Boot Sequence Using extlinux.conf] for details.
Could you please let me know one more thing, Do we need to define overlay dtsi file? I have created for Ar0820: tegra194-camera-ar0820-a00.dtsi and platform dtsi file where GPIO is defined: tegra194-p2822-0000-camera-ar0820-a00.dtsi.
Is these files are enough to run my v4l2 camera module?
If overlay files like: tegra194-p2822-camera-imx185-overlay.dts this file need to be created then how to understand these parameters? Where i can find the detail information of these overlay parameters?
I’m building the whole kernel code like:
cd ~/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/sources/kernel/kernel-5.10/
and then running the below commands:
make mrproper
make ARCH=arm64 O=$KERNEL_OUT tegra_defconfig
After make… then i m copying the Image and dts files to kernel folder:
cp ./arch/arm64/boot/Image $JETPACK/kernel/
cp -r ./arch/arm64/boot/dts/nvidia/* $JETPACK/kernel/dtb
then…
then flash everything, using:
Am i doing correct? As after building the complete kernel files and flashing everything makes the Jetson machine unstable. I’m seeing blank screen and not able to get boot up properly. Login screen is not coming up and boot seems to fail or hang.
by default. it’s CBoot functionality to load kernel image and device tree blob via file system.
please refer to /boot/extlinux/extlinux.conf, it’s LINUX and FDT entry to specify the path of those binaries. you may try using scp to copy your binary files to target for testing.
