How to ./flash.sh only flash qspi device all partition
assuming your question is that “How to use flash.sh to flash only the QSPI memory, not storage devices.” Please try this command: (if you are using an AGX Orin)
sudo ./flash.sh -c bootloader/t186ref/cfg/flash_t234_qspi.xml jetson-agx-orin-devkit mmcblk0p1
- Thank you very much for your help. * According to your method, the problem has been solved, thank you very much.
