After rm -rf /, I tried to flash dual tegras in parallel again and again, but I did not work.
error-aurix-command
Bootburn operation unsuccessful
The following tips can help troubleshoot bootburn failures. These are based on
known issues related to setup or missing configuration. If it doesn’t help
resolve the issue, contact module owners with a copy of the full log.
error= error-aurix-command
- The Aurix console did not regognize the command given to it. Please review
the logs and make sure that the command that you are sending is valid
bootburn flashing failed! error code = 37
