Hello Kristian,
Many thanks for posting your inquiry on the Mellanox Community.
Based on you information, FreeBSD driver version 3.5.0 is not supported for FreeBSD 11.2. See the following link to the RN → http://www.mellanox.com/related-docs/prod_software/Mellanox_FreeBSD_Release_Notes_3.5.0.pdf
Supported FreeBSD version is 12.
As of version 3.5.1 our driver code is completely upstream, incorporated with the distribution. No need to install any additional driver s/w from our site.
Under FreeBSD 12.0 and with driver version 3.5.0, we do not experience any issue, when using the ‘build.sh’ script provided with the driver.
Lab output:
root@bsd-freebsd12:/var/tmp/freebsd-v3.5.0 # ./build.sh
Kernel build directory is /tmp/tmp.JkQBbgQe
Don’t forget to do ``make cleandepend && make depend’’
FLAGS=WITHOUT_OFED=YES KMODDIR=/boot/kernel SYSDIR=/usr/src/sys -m /usr/src/share/mk KERNBUILDDIR=/tmp/tmp.JkQBbgQe
The FreeBSD source tree is at /usr/src …
===> linuxkpi (clean)
===> linuxkpi (cleandepend)
===> linuxkpi (depend)
===> linuxkpi (all)
===> linuxkpi (install)
scripts/ibdev2netdev → /usr/bin/ibdev2netdev
scripts/set_irq_affinity_freebsd.sh → /usr/bin/set_irq_affinity_freebsd.sh
scripts/show-pretty-gids-freebsd.sh → /usr/bin/show-pretty-gids-freebsd.sh
root@bsd-freebsd12:/var/tmp/freebsd-v3.5.0 # kldload -v mlx5
Loaded mlx5, id=7
root@bsd-freebsd12:/var/tmp/freebsd-v3.5.0 # kldload -v mlx5en
Loaded mlx5en, id=9
root@bsd-freebsd12:/var/tmp/freebsd-v3.5.0 # kldstat -v | grep -i mlx
181 pci/mlx
180 mlx/mlxd
7 2 0xffffffff82c1e000 3c060 mlx5.ko (/boot/kernel/mlx5.ko)
9 1 0xffffffff82c6b000 14200 mlx5en.ko (/boot/kernel/mlx5en.ko)
Many thanks,
~Mellanox Technical Support
