How to form the frame from TensorRT output
I have a custom image preprocessing neural network model. It takes input of 1920x1080x3 and outputs 1920x1080x3 (It basically does preprocessing, so input is an image and output is an image).
I successfully tested code in Python and in ONNX.
However, I want to run the code in tensorRT C++. So, I took this code from github, and modifying it run my .engine file.
I read the image using
  image = cv::imread(path);
  cv::resize(image, image_resize, cv::Size(1920,1080), cv::INTER_LINEAR);
  cv::cvtColor(image_resize, image_cvtColor, cv::COLOR_BGR2RGB);
then created blob and copied it to GPU memory for inference,
cv::dnn::blobFromImage(tmp, out, 1 / (255.f), cv::Size(), cv::Scalar(0, 0, 0), false, false, CV_32F);
I read back the result using,
   // cv::Mat image = cv::Mat(width, height, CV_8UC4, (unsigned*)data);
    cv::Mat output1 = cv::Mat(num_rows, num_cols, CV_32F, static_cast<float*>(this->host_ptrs[0]+(0))); //CV_32F
    cv::Mat output2 = cv::Mat(num_rows, num_cols, CV_32F, static_cast<float*>(this->host_ptrs[0]+(7680))); //CV_32F
    cv::Mat output3 = cv::Mat(num_rows, num_cols, CV_32F, static_cast<float*>(this->host_ptrs[0]+(7680*2))); //CV_32F
    // Scale and convert floating-point data to 8-bit unsigned integers
    cv::Mat output1_8U, output2_8U, output3_8U;
    output1.convertTo(output1_8U, CV_8U, 255.0);
    output2.convertTo(output2_8U, CV_8U, 255.0);
    output3.convertTo(output3_8U, CV_8U, 255.0);
    // Combine the channels into a single RGB image
    std::vector<cv::Mat> channels = {output3_8U, output2_8U, output1_8U}; // BGR order
    cv::Mat rgbImage;
    cv::merge(channels, rgbImage);
    // Display the combined RGB image
    cv::namedWindow("win_name1", cv::WINDOW_NORMAL);
    cv::imshow("win_name1", rgbImage);
    cv::waitKey(0);
I think, I am doing something wrong here. I am getting output in grayscale. Am I doing any mistake in NxCxHxW to NxHxWxC ?
My input image is like this.
Ideally, I should get sharpened output, but I am getting output like this.
How to read pixels from static_cast<float*>(this->host_ptrs[0]+(0)).
Please provide complete information as applicable to your setup. Ideally I should read 6220800 (1920x1080x3) pixels from this address.
TensorRT Version : 8.4.1
GPU Type : A5000
Nvidia Driver Version :
CUDA Version : 11.4
CUDNN Version :
Operating System + Version : Ubuntu 20.04
Python Version (if applicable) : No, running on C++
TensorFlow Version (if applicable) : NA
PyTorch Version (if applicable) : NA
Baremetal or Container (if container which image + tag) : NA
Please refer to the python and onnx code which you have run successfully. If the output layer dimension is NHWC(as you have said the model output 1920x1080x3), the R, G, B values are mixed.
Hi @Fiona.Chen,
Generally, to send the image to ONNX runtime we first convert time image to NCHW right?
Here is my code which feeds the image to ONNX runtime engine.
img = Image.open("image.jpg")
resize = transforms.Resize([1080, 1920])
img = resize(img)
to_tensor = transforms.ToTensor()
img = to_tensor(img)
print("Tensor image size {0}".format(img.shape))
# We need to have batch size as one. So, lets unsqueeze it
img.unsqueeze_(0)
print("Tensor image size after unsqueeze is {0}".format(img.shape))
ort_inputs = {ort_session.get_inputs()[0].name: to_numpy(img)}
ort_outs = ort_session.run(None, ort_inputs)
And this is how I am getting the result from runtime engine. Which is working perfectly.
# Lets inspect the output tensor size
print(len(ort_outs))
# Since, we have passed only one image, we are getting the data from 0th index
img_out_y = ort_outs[0]
print("Image size out ONNX tensor output {0}".format(img_out_y.shape))
# Let us remove the batch (since we have only one image)
img_out_y = img_out_y[0,:,:,:]
print("Image size after removing the batch {}".format(img_out_y.shape))
# For PIL or CV2, we want W H DIMENSION. That is why, transforming the matrix
ONNX_filtered_img = np.asarray(img_out_y).transpose(1,2,0)
print("Transformed image size {}".format(ONNX_filtered_img.shape))
I have done inference of ONNX in python. I don’t know how to do it in C++
Hi @Fiona.Chen
I solved my issue!! Here is the code (it may help someone in future)
    /* Lets get information about image output */
    auto num_channels = this->output_bindings[0].dims.d[1];
    auto num_rows  = this->output_bindings[0].dims.d[2];
    auto num_cols  = this->output_bindings[0].dims.d[3];
    /* Print them only if necessary */
    #if 1
    std::cout << "num_channels " << num_channels << std::endl;
    std::cout << "row_output " << num_rows << std::endl;
    std::cout << "col_output " << num_cols << std::endl;
    #endif
    /* Image will be stored as continous array like as illustrated below
        _________________________________________________
        |   R PIXELS    |   G PIXELS    |   B PIXELS    |
        |  (1920x1080)  |  (1920x1080)  |  (1920x1080)  |
        |_______________|_______________|_______________|
       base             base            base
       address          address +       address +
                        1980x1080       1920x1080x2
    cv::Mat output1 = cv::Mat(num_rows, num_cols, CV_32F, static_cast<float*>(this->host_ptrs[0])+((num_cols*num_rows*0)-0));
    cv::Mat output2 = cv::Mat(num_rows, num_cols, CV_32F, static_cast<float*>(this->host_ptrs[0])+((num_cols*num_rows*1)-1));
    cv::Mat output3 = cv::Mat(num_rows, num_cols, CV_32F, static_cast<float*>(this->host_ptrs[0])+((num_cols*num_rows*2)-1));
    /* Bring float values to 0 <--> 255 */
    /* Combine the channels into a single RGB image */
    cv::Mat rgbImage;
    /* Display the combined RGB image */
    cv::namedWindow("Result", cv::WINDOW_NORMAL);
    // cv::imwrite("saved_image.jpg", rgbImage);
    cv::imshow("Result", rgbImage);
    cv::resizeWindow("Result", 1920/2, 1080/2);
    //cv::waitKey(0);
