How to free gpu and memory usage in deepstream app
• Hardware Platform (Jetson / GPU) Jetson Orin Nano
• DeepStream Version 6.3
• JetPack Version (valid for Jetson only) 5.1.2
• TensorRT Version
I am running a deepstream application and I am looking for anyway to free some GPU/CPU usage and memory.
I have tried to increase the interval and lower the source FPS, but haven’t changed anything.
Do you have any suggestion?
Is it our demo application? In theory you can reduce memory and gpu usage by doing the following.
  1. Reduce the number of your sources
  2. Reduce the resolution, bitrate, fps of your stream
  3. Set “interval” parameter to the nvinfer
  4. Set an appropriate batch-size(we recommend the same number of video sources)
  5. You can try to use trtexec to test the performance first
./trtexec --loadEngine=xxx.engine --fpxx  --batch=x
