I got a problem with the speed of my CUDA code.
I’m programming a Convolution Neural Network for an image detection / classification in c++ ( Visual Studio ).
The classification and detection works, but I have speed problems, only in the Dense Layer.
I wrote the same algorithm in CPU-code to check out the speedup. On CPU it takes 45 seconds, on GPU 6 seconds for an image with the size of 750 x 500 pixels. So it’s an improvement, but I know that my code is far from being efficient.
First of the minimized Kernel:
__global__ void denseKernel(
float *denseMap, // output image
float *inputImg_0, // input image
int *pixel_location,// used pixel
float *w, // multiplied and added weight
int *featuresize,
int *sizex, // image width x-direction
int *offset, // variable for right vector multiplication
bool *flag, // flag for threshold and bias
float *bias, // bias for addition
int *amount_pixel
int i = blockIdx.x * blockDim.x + threadIdx.x;
int z = 0;
if (i < *amount_pixel)
for ( int x = 0; x < *featuresize; x++ )
for ( int y = 0; y < *featuresize; y++ )
denseMap[pixel_location[i]] += ( ( w[z++] )
*( inputImg_0[pixel_location[i]
+ *offset
+ x* *sizex
+ y
if (*flag) // Addition of the bias and threshold in the last channel
{ // addition of the bias
denseMap[pixel_location[i]] = denseMap[pixel_location[i]] + *bias;
//// Tangen Hyperbolicus as threshold
denseMap[pixel_location[i]] = tanh(denseMap[pixel_location[i]]);
This kernel is called 1024 times in this case. In the host code I allocated all necessary variables in global memory via cudamalloc() and cudamemcpy().
These allocations take ~50 ms only once. So it’s not the bottleneck.
The kernel is called like:
int sizeN = amountPixel; // 750 x 500 pixels
int warpsize = 256;
dim3 blocksPerGrid( ( ( sizeN / warpsize ) + 200 ), 1, 1 );
dim3 threadsPerBlock( warpsize, 1, 1 );
// Launch a kernel on the GPU with one thread for each element.
denseKernel << < blocksPerGrid, threadsPerBlock >> >
*dev_denseMap,
dev_inputImg_0,
dev_pixel_location,
dev_w,
dev_featuresize,
dev_sizex,
dev_offset,
dev_fresize,
dev_flag,
dev_bias,
dev_amountPixel
The actual parallelization is that I compute all necessary pixels with the GPU.
I trained the weights with Theano / Lasagne and CUDA / cuDNN implementation. I then used this weights to optimize the CNN for my special needs. In Theano a pixelwise classification took ~40 s.
I know that the bottleneck in my denseKernel()-code are the two for()-loops, but I do not know how to parallelize these loops in addition to the first SIMT-parallelization in the same kernel.
I posted this question first at stackoverflow, but apparently they said it’s not the rigth forum for my question.
https://stackoverflow.com/questions/46910155/how-to-further-speedup-a-cuda-code-for-a-convolution-neural-network/46917294#46917294
I hope you understand my question and thank you in advance!
