How to generate a picture file while using Gst-nvsegvisual plugin?
I am using the the Gst-nvsegvisual – deepstsream segmentation plugin to create an application.
In this application, instead display the segmentation picture on the window, I want to save that as a file. I try to set:
sink = gst_element_factory_make (“filesink”, “file-sink”);
nvsegvisual = gst_element_factory_make (“nvsegvisual”, “nvsegvisual”);
but I can not get gst_element_link_many() call work, it gives the error:
“Elements could not be linked: 1. Exiting”
I think that nvsegvisual caused the function call failed.
Can some one let me how to generate the picture file?
Jimmy
• Hardware Platform (Jetson / GPU) – dGPU
• DeepStream Version - 5.0
• TensorRT Version -7.0
• NVIDIA GPU Driver Version (valid for GPU only) - 450.80
• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description) Gst-nvsegvisual
Can you refer to the sample of segmentaion? It is in /opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-segmentation-test.
solved the problem by using the following pipeline:
H264/JPEG–>decoder–>tee -->| – (batch size) ------>|–>streammux–> nvinfer–> nvsegvisual → vosd → |—> encode —>filesink (save the output in local dir)
