How to generate and verify an INT8 calibration cache (.cache) for trtexec on on Jetson Nano (TensorRT 8.2.1.8) — Polygraphy failing on-device
I have a custom trained model converted to .engine file using trtexec for both FP32, FP16 on Jetson Nano and have also used them for inference(example code https://github.com/NVIDIA-AI-IOT/yolo_deepstream).
I now need to convert the same custom model to INT8 for which I need an INT8 calibration cache (.cache) that trtexec --calib=<file> will accept and use.
Environment :
  • Device: NVIDIA Jetson Nano Developer Kit
  • L4T / JetPack: L4T 32.7.1 / JetPack 4.6.1
  • OS: Ubuntu 18.04.6 LTS (kernel 4.9.253-tegra)
  • CUDA: 10.2.300 (arch 5.3)
  • cuDNN: 8.2.1.32
  • TensorRT: 8.2.1.8
  • Python: 3.6.5
Queries:
  1. how to generate a valid INT8 calibration cache (calib.cache) for trtexec
  2. how to confirm the cache was used for generation of the int8 engine file
  3. why Polygraphy fails on Jetson Nano in this environment (is Python 3.6.5 the blocker?). Is there an alternative?
i intend to use the calib.cache with the trtexec cmd line tool with the flag --calib=calib.cache.
The command i will use for conversion to INT8 is :
/usr/src/tensorrt/bin/trtexec --onnx=/path/to/input/onnx/weight/file --saveEngine=/path/to/output/engine/weight/file --int8 --fp16 --workspace=4096 --profilingVerbosity=detailed --calib=/path/to/input/calbration/data/cache/file
Hi Mehrul,
Thanks for posting on the developer forums! Moving your post to the Jetson Nano section to have more visibility.
Thanks,
AHarpster
Thanks for the help.
Please check the TensorRT document below:
Jetson Nano (same hardware architecture as TX1) doesn’t support INT8:
