malith
November 5, 2019, 12:17am
#1
I have added new parameters to the sources/apps/apps-common/src/deepstream_config_file_parser.c -> parse_dsexample(). And I tried to generate object file by running the following command
$ gcc -Wall deepstream_config_file_parser.c -o deepstream_config_file_parser
And I got this error
deepstream_config_file_parser.c:23:10: fatal error: deepstream_common.h: No such file or directory
#include “deepstream_common.h”
amycao
November 6, 2019, 8:29am
#2
you should build deeptream-app and dsexample plugin, not build this single source.
malith
November 12, 2019, 1:36am
#3
I use dsexample plugin on objectDetector_Yolo. So first I have built the dsexample plugin by running the following command
sudo CUDA_VER=10.0 make install
Then I have built the objectDetector_Yolo app by running the following commands
export CUDA_VER=10.0
make -C nvdsinfer_custom_impl_Yolo
But the issue remains same. If my steps are wrong, please tell me the correct steps to build the app and plugin.
amycao
November 12, 2019, 3:49am
#4
it’s for deepstream-app
you can refer to source code, sources/apps/sample_apps/*, any sample for how to use a plugin.
