I am using CUDA Fortran and want to generate a Poisson-distributed random “integer” number using curand.
But the variable type for output values in curandGeneratePoisson function is defined as “real”.
integer(4) function curandGeneratePoisson(generator, array, num, lambda )
type(curandGenerator) :: generator
real(8), device :: array(*) ! Host or device depending on the generator
integer(kind=c_intptr_t) :: num
real(8) :: lambda
I do not understand why the output values are not “integer” type.
When I input an integer type variable for “array”, I received type mismatch error.
On the other hand, when I input a real type variable for “array”, all the results are 0.
Does anyone know how to generate a Poisson-distributed random “integer” number using curand?
Looking at your code in this channel, I wrote the following one to generate double precision random number with normal distribution. However, its outputs are zero only. Could you help me in this regard. Here is the modified code:
program testcurand1
call foo1(100)
end
subroutine foo1(n)
use cudafor
use curand
real*8, managed :: a(n)
real(8) :: mean, stddev
interface
real8 function curandGenerateNormalDouble2(gen, array, num, mean, stddev) &
bind(C, name=‘curandGenerateNormalDouble’)
import curandGenerator
!DIR$ IGNORE_TKR (K) num, (D) array
type(curandGenerator), value :: gen
real8, device :: array(*)
integer(kind=int_ptr_kind()), value :: num
real(8), value :: mean, stddev
end function
end interface
a = 0
mean = 0.d0
stddev = 0.d0
passing = .true.
istat = curandCreateGenerator(g,CURAND_RNG_PSEUDO_DEFAULT)
istat = curandSetPseudoRandomGeneratorSeed(g, 1234)
istat = curandGenerateNormalDouble2(g, a, n, mean, stddev)
istat = cudaDeviceSynchronize()
istat = curandDestroyGenerator(g)
print *, a
end
The code posted above has one mistake that I have set stddev=0. That is why its output was all zero. Setting any desired stddev, it will work accordingly.
