I would like to generate 40MHz clock from the Jetson AGX PWM.
I haven’t found a proper tutorial for configuring the pinmux fot PWM, nor setting the PWM configuration.
I succeeded changing the PinMux by changing Jetson_AGX_Xavier_Series_Pinmux_Configuration_Template.xlsm and running pinmux-dts2cfg.py
I now have an updated tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg file under /Xavier/L4T-bsp/bootloader
